Mark Heaps wrote: ↑Wed Sep 05, 2018 6:14 pm
I think Adrian Harris nailed it on the head. Your T-FHSS capable transmitter can talk to a T-FHSS receiver and is also capable of talking to a S-FHSS receiver. The S-FHSS receiver can MAYBE talk properly to the Armortek components, the T-FHSS receiver apparently cannot.
You may want to go with a different TX/RX combination. On my first ever foray into the RC world, I was able to set up a brand new Spektrum DX7 with AR8000 receiver using the guides on this forum to successfully benchtest all the motors on my KT kit ( bought second hand so the Armortek modules are quite a few years old ) with no problems experienced. Later transferred the AR8000 into a second-hand SdKfz 7 and within 5 minutes of adjusting the settings on the DX7, that was running as it should with one-stick control.
Go for a TX/RX combination that is known to work.
Hi Mark and Adrian,
I have received a brand new
RS-2008SB S-FHSS receiver yesterday.
- R-2008SB.jpg (21.11 KiB) Viewed 8052 times
So I did
1), Replace the RS-3008SB T-FHSS receiver with
RS-2008SB S-FHSS receiver, and
2), Change the RX mode from
T-FHSS to
S-FHSS in T10J transmitter, then
3), Try to
link the T10J transmitter with
RS-2008SB S-FHSS receiver as per the link procedure.
The outcome? Still no good.
(a), The Receiver became
LED blinks Green, instead of
steady Green.
(b), The Link ID is not showing the Receiver number, only the bar character "— — — — — — — — —— —".
The T10J/RS-3008SB Manual does saying that by switching into
S-FHSS mode, it is compatible with the
RS-2008SB FHSS receiver.
Is there anything I've been missed? Any suggestion is welcome.
