Current motion pack with Blank system - advice
All topics related to Armortek's Motion Option Pack
David Stewart
Been liked: 11 times
Post by David Stewart »
Morning all
Just in the process of testing all the electrics before i fit to my Tiger 1. I am fitting the current generation electronics to my 2010 Tiger 1.
I have a question for everyone, I have the old blank firing kit with my tank as am curious how to connect it into the system. Can I patch it in via the new module or just straight into a channel on the Tx?
Has anyone else connected these systems up?
For reference I have no interest in using the audio option pack.
Any help/advice would be appreciated
Armortek 2010 Mid Tiger 1
Has liked: 1419 times
Been liked: 1594 times
Re: Current motion pack with Blank system - advice
The Blank Firer just has a simple 24V motor to turn the magazine. You should be able to use one of the switched outputs from the Motion Control Module but be aware the Blank Firer must only turn in one direction as there are cams built into the system which will be damaged if you try and rotate it the wrong way.
I can't remember when it was phased out but you also need to check that your barrel and muzzle brake are of the correct design to use the Blank Firer, or you will be in contravention of the agreement for its use. The muzzle brake must screw onto the barrel, and it must have the "pepper pot" restrictor to prevent any debris from exiting the barrel.
David Stewart
Adrian Harris wrote:
Sun Jun 17, 2018 1:54 pm
Afternoon Adrian
Thanks for the advice, my kit has the pepper pot style muzzle brake.
