Early Tiger 1 - 2003 vintage - turret deck bend
Sam Hough
Has liked: 68 times
Been liked: 53 times
Re: Early Tiger 1 - 2003 vintage - turret deck bend
Post by Sam Hough »
I was hoping to get away with workmate and brute force :(
Probably have one where I work but not sure who to be nice to...
Sam Hough
Has liked: 68 times
Post by Sam Hough »
I'm going slightly mad trying to be sure I'm putting all the turret things in the right position.
Got this aerial of the 131 (or is it CGI?)
(Image from/copyright Fury 2014)
Really think they should have taken the cover off the air intake before battle ;) Does the 131 have the air intake under the cover or is it missing?
Simon Peck
Has liked: 7 times
Been liked: 46 times
Post by Simon Peck »
I stand to be corrected; the ventilator (inlet fan) is under a armoured cover on the forward hull roof, between the driver and radio operator hatches. The extract on an ‘early’ Tiger is towards the rear of the turret roof. It was later moved to abovevthe gun breach, but that’s a later version of Tiger than yours. The pic should help.
Sam Hough
Has liked: 68 times
Post by Sam Hough »
Thanks Simon,
I did mean the ventilator fan. The bit I'm stuck on now is that if I follow the position given in http://tiger1.info/EN/First-turret-fan.html the fan seems to be too far forward and to the right.
All the other photos/diagrams I can find including:
seem to show the side of the stowage box "pointing" near to the centre of the fan.
Looks like a good book, which one is it?
Thanks again
Sam
Has liked: 1421 times
Been liked: 1598 times
Allowing for some distortion because the photo isn't directly overhead, the diagram and the photo line up quite well, which means there may be an error in the dimensions.
Untitled-1 copy.jpg (84.1 KiB) Viewed 1946 times
Sam Hough
Has liked: 68 times
Post by Sam Hough »
Thanks Adrian,
Great minds.. I've spent the weekend going crazy comparing eight different images fading them in and out.
Even more pronounced against Fury/131/(CGI?)
All the other sources I have seem to align. I might lift the position from the diagram in the Tamiya 1/16th instructions.
NB I checked and the numbers match the image proportions in the image from tiger1.info
Sam
Simon Peck
Has liked: 7 times
Hi Sam,
I agree with you ref the turret bin edge ‘pointing’ at the ventilator. If you go to FB, there’s two groups there; Tiger Tanks and Tiger Tracks. David Byrden (TigerI info) is a member, so you can ask him direct.
The book is good, worth having but out of print. It’s not worth the crazy second hand asking prices you’ll see, and there’s no info in it you can’t get elsewhere.
Do you know what source or reference was used when your Tiger kit was designed, it might help explain anomalies?
Simon
Sam Hough
Has liked: 68 times
Post by Sam Hough »
Thanks Simon,
I'm not sure what sources were used for the 2003 version, it was a few owners of Armortek ago and I think widely accepted that some problems.
I'll try and contact David Byrden.
Sam
