17 Pdr Pheasant
All topics related to Armortek's 17 Pdr
Marcus Kwa
Been liked: 39 times
Re: 17 Pdr Pheasant
Post by Marcus Kwa »
Dave,
Will you do an oil can for on that oil-can-tray? I had three attempts on it and all failed miserably........
Marcus
Robert Reid
Has liked: 99 times
Been liked: 446 times
Re: 17 Pdr Pheasant
Post by Robert Reid »
That's a Braimes Oiler.... Fitted to half the pre-war British cars (including the LeMans Bentley's).
Probably not hard to replicate if you see an original!
http://www.model-engineer.co.uk/sites/7 ... 766779.jpg
RPR
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Re: 17 Pdr Pheasant
Something like this maybe?
Dave
www.armorpax.net
Marcus Kwa
Re: 17 Pdr Pheasant
Whow! Superb!! A real gem!
I think that concludes my wishlist......
By the way you have inspired me to start building again: I have cleaned my 25 pdr/pheasant (cracked sewage pipe flooded my basement and workspace....) and started removing the rust from the turning platform. Luckely I brazed all parts together and all welds are still holding!!
Marcus
Re: 17 Pdr Pheasant
Hi All,
Package arrived from Marcus today and after a little work with the file, to fit the barrel, and the second set of bolt holes adding the Barrel counter weight is done and textured with Mr Surfacer
Dave
www.armorpax.net
Marcus Kwa
Re: 17 Pdr Pheasant
I used the Comet barrel for my Pheasant which probably has a different barrel outerdiameter. That filing was quite some work since I made the base of that counterweight from aluminium!
Marcus
Re: 17 Pdr Pheasant
Hi All,
New Hook and end plate set now fitted.
Dave
www.armorpax.net
Re: 17 Pdr Pheasant
Hi All,
0.5mm thick Lead foil arrived today so started making some of the straps. I used to use the 0.1mm version of this on 1/35th and 1/16th scale stuff so, as webbing and straps are getting harder to find in 1/6th, thought I'd give it a go. Please remember this is lead sheet so if you decide to use it ensure you wash your hands after and keep it away from children
Dave
www.armorpax.net
Re: 17 Pdr Pheasant
Hi All,
Last of the straps added. Going to make a start on the modified firing lever tomorrow.
Dave
www.armorpax.net
Re: 17 Pdr Pheasant
Hi All,
Modified firing handle assembly done which means its almost finished. A few small details to make and the new metal parts to add back on when I get them.
Dave
www.armorpax.net
Marcus Kwa
Re: 17 Pdr Pheasant
O yes! The icing on the cake!!
I found small diameter (compression) coil springs on ebay (nickcwizardscx) which I used for the actuator rods for the brake system (see photo), but would also look good on that firing mechanism! Sizes 1.5 to 25.4mm diameter are available in 300 or 600mm lengths. I used the 2.4 and 3.0mm varieties.
Marcus
Fabrice Le Roux
Been liked: 14 times
Re: 17 Pdr Pheasant
Post by Fabrice Le Roux »
Hi Dave,
Great project. Glad hand on mend.
Think your brass turnbuckles may have come from here:
https://knupfer.info/shop/index.php/deu ... ser-g.html
Knupfer's have a lot of very useful small parts for scratchbuilders, and provide a fast and reliable service.
Always a pleasure following your builds.
cheers
Fabrice
Dave Backway
Has liked: 12 times
Been liked: 64 times
Re: 17 Pdr Pheasant
Post by Dave Backway »
Good evening Dave,
As always the build and the details are looking good. Will the oil can be available on your site so I can add it to may 25pounder with your detail kit?
Best regards Dave
Re: 17 Pdr Pheasant
Hi Dave,
Yes, we are bringing out an update set for the 25 Pdr shortly to include the new parts but the oil can will also be available as an individual item as I can see it having uses other then the 25 Pdr :-)
Dave
www.armorpax.net
Re: 17 Pdr Pheasant
Hi All,
Resin cast firing handle assembly for the 17 Pdr Pheasant. The unassembled one is yours Marcus :-)
I'll post out once I've cast the counter weight later this week all being well.
Dave
www.armorpax.net
