Anyone ever had a can of Upol Acid 8 etch primer with no 'Pzzzt' in the can ?
Just started a new can I bought last year and it's terrible - hardly any paint dispersed and very uneven coverage. I've tried the nozzle from the previous can and that's no better
I've been shaking it for a good five minutes, as I knew it had been on the shelf for a while. It' s been in the spare bedroom, so not exposed to extremes of hot or cold.
I don't know if the can is faulty or the valve, as it seems to have a very small sweet spot of finger pressure which gives a better spray, but not even close to the previous can.
"Flat" aerosol cans
- Has liked: 1421 times
- Been liked: 1603 times
"Flat" aerosol cans
- Has liked: 1024 times
- Been liked: 2094 times
Re: "Flat" aerosol cans
Yes, I've had two like that with Upol Acid 8, as you say, stored in good conditions but sat on the shelf for a few months. No "Pzzzt". Tried everything to produce some output without success. If anyone has a reliable remedy it would save us all a lot of money. Stephen
- Been liked: 1 time
OH Dear!!!!! disaster. as they say in the west country ' cor bugger jagger' Denny.
- Been liked: 1661 times
hi adrian, buy the u-pol acid etch primer of e-bay x 12 cans £66.00, you can buy in smaller quantaties and it's cheaper, not the acid 8, thats a high build primer we dont need, warm the can you have with a hairdryer gently, if there's no pressure after that when it's warm it's u.s. don't throw it away, cut the can open and use the contents, mind your finger's, regards simon.
- Been liked: 33 times
Hi there
Yes most primers need worming up before use it helps them atomize . I just stand mine i a sink with a bit of warm water for a few of minutes.
Regards Andy Q
Regards Andy Q
