Panzer III coming soon - Spring '18
Been liked: 3697 times
Great news for all Panzer III fans out there - we will be re-releasing a very limited run - only 25 kits.
Shipping will be towards the end of spring - price and shipping date to be confirmed in the next week or so.
For the FAMO fans out there - there is no impact on the FAMO ship date as the PIII will be manufactured whilst we are designing and prototyping the FAMO.
Kian
Tim Page
Has liked: 40 times
Been liked: 471 times
Re: Panzer III coming soon - Spring '18
Post by Tim Page »
That is good news for many Panzer 3 fans out there.
Will you be making any improvents to the kit or re-releasing exactly how it was done previously.
I ask because the aftermarket parts that Steve Winstone produced are a nonger available.
It would be great to get the road wheel profiles a bit closer to prototype and also a better scaled (smaller) Cupola would also be brilliant.
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Enlarging the front access hatch and re doing the the rear deck plates would seem to be a good improvement as well as Tims suggestions
Tim Page
Has liked: 40 times
Post by Tim Page »
Oh yes, modding that front access hatch is not a lot of fun to do and i managed to kill my Proxon when cutting out the hole.
One other thought would be if you could do a Schurzen kit as an upgrade for the Panzer III.
Maybe offering the Hull and Turret kits as two separate options.
I am wanting to add Turret Schurzen for my Panzer III.
Tim.
proberbly the best 1/6 scale value for money metal tank produced by any company, glad to see it back, regards simon manning.
Has liked: 1038 times
Agree with Simon, there is so much scope for fine detail, it's a much more complicated tank than its bigger German cousins.
I did a piece on the re-profiling of the roadwheels here:
http://www.armortek.co.uk/Forum3b/viewt ... &start=285
and I put the definitive profile here:
http://www.armortek.co.uk/Forum3b/viewt ... =15&t=2545
There are a few other important corrections which Mark might consider:
- reduce the diameter of the cupola to scale and re-position to the rear
- increase the angle of the sloping top front turret plate and adjust the side armour plates accordingly. (I think this is the most important change visually)
- reproduce the characteristic curve of the track guards seen in side profile, they're currently flat, whereas the front and rear sections should slope downwards.
- correct the overhang of the hull top rear plate
- as mentioned by Mark and Tim, resize the engine access hatches (if it wasn't already done on the second production run)
- if it's economic to do so, produce the correct circular section to the roadwheel swing arms
- and a final wish, which is probably viable neither financially or practically: introduce the hollow track horns
I couldn't think of a better choice for a re-run of a fine Armortek model. Kept me amused for years.
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
My latest master is suddenly quite apt. Tim asked me for an aerial base at SW model show and hey presto more Panzer III's it could be fitted to :-)
Dave
www.armorpax.net
We are now opening pre-orders for the PIII.
The 2018 PIII will come with several improvements -
The most significant from an engineering perspective is the TURRET SIDES MACHINED FROM SINGLE PIECE OF ALUMINIUM
This will give a level of accuracy of fit not seen before !
Have a look at the picture below to see the size of the block that we will be using.
From a modelers perspective the most significant improvements are:
  • REVISED WHEEL PROFILE
  • BALL BEARING TURRET RING
  • REVISED REAR DECK PROFILE AND OVERHANG
  • REVISED (SMALLER) CUPOLA
  • REPOSITIONED CUPOLA
  • ASSYMETRIC FRONT ACCESS HATCHES
  • INCREASED FRONT TURRET SLOPE
  • REVISED MAIN MUDGUARD LINE
  • SEMI RADIUSED SWING ARMS
  • ADJUSTABLE ANGLE TORSION BAR
  • ALL ALUMINIUM DECK AND BELLY PLATES
Pricing will be GBP3,295 (USD 4,795 or EUR 3,895 if paid by bank transfer to our USD & EUR accounts respectively ) plus VAT (where applicable) and P&P.
To reserve your model, please contact us as sales@armortek.co.uk to pay a deposit.
