Problems with sound unit
David Hopkins
Post by David Hopkins »
I have an early tiger and a mid tiger both with the original sound units when I built the tanks and wired in all the electrics the sound units worked for the first (five minutes) and then they stopped and haven't made a sound since, pardon the pun. Is this a common problem with the original sound units or something I may have done wrong with the wiring? Although I believe the wiring I done is correct beacuse everything else in the tank works. Can anybody shed any light on this? :roll: :roll:
-Dave
leesellars
Been liked: 15 times
Post by leesellars »
Hello David
The early sound modules from armortek Are allright but you do get the sounds coming off and on when required. I would recomend that you upgrade the sound to the new benedini system. Its very good also you get 8 sounds on it.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
David Pengelly
Been liked: 2 times
Post by David Pengelly »
Hello David ,
i also had a similar problem with my early sound system in the tiger1. I changed the switchers for the turret rotation, and gun elevation to esc,s and this cured the problem. In some cases the switchers give back emf ( or so i am told ) and this affects the sound system.
The later Benedini system doesnt suffer the same problems , and as Lee says its much better .
Was die Hölle das war
David Hopkins
esc switches
Can you tell me more information regards these switches, where they go and what they wire into and what are they??
Best Regards
Mick Regan
Has liked: 34 times
Been liked: 6 times
Post by Mick Regan »
Hi David
The switch units are the 2 smaller of the Electronize units. They are use to control the turret rotation and gun elevation motors. They look like the one arrowed in the picture below
If you need any more info, look at the Electronize site at http://www.electronize.co.uk/model_elec ... frames.htm
Hope this helps
Mick
