Martin's Jagdpanther
- Martin Hofmann
- Has liked: 149 times
- Been liked: 1898 times
Re: Martin's Jagdpanther
Hello Gerhard,
that means the steel sprocket rings are for ever???
Here comes the next photos of the tools and racks
Regards Martin
- Martin Hofmann
- Martin Hofmann
Here comes the very beautiful parts from Steve Winstone. Thank you Steve for this great design!!!! I also bring weldings to the several parts.
Regards Martin
- Paul Wills
- Has liked: 646 times
- Been liked: 142 times
Very nice work Martin, shopping in the craftsman's market is like being a child in a sweet shop.
Paul.
Paul.
- Has liked: 2267 times
- Been liked: 7152 times
Martin, I can see you are enjoying yourself....nice work
- Martin Hofmann
Hi Paul and Phil,
it is very much better to shop in a craftsman's market because there a no calories in the parts!!!
Here are the next weldings of the bumpers and the tow hitch.
The last photos shows the new steel sprockets and rings after laser treatment without machining.
Regards Martin
- Has liked: 732 times
- Been liked: 333 times
Wow, serious work Martin! I wish I had your skills.
What compound are you using for your welds? They look a little rounder (not so pointy sharp) than most I have seen. Very realistic!
/Chris
/Chris
- Martin Hofmann
Hi Chris,
thank you for the compliments, i use Milliput white/red for the weldings and a oval tool to make the welding bead. Thicker sheets gets more than one row of welding.
Here are Steve's parts after priming and painting.
Regards Martin
I like
- Paul Wills
Every new photo is a step closer to the finished model, and its looking good
Paul.
Paul.
- Martin Hofmann
Hi Phil and Paul,
thank you for your and
here are the next photos about the swing arms prepared for drilling, new covers for the hull and the hub caps with their securing plates for the screws.
Regards Martin
- Martin Hofmann
Hi all,
here are the next photos of the in- and outtake grills with some modifications.
Regards Martin
- Martin Hofmann
Now here comes the next photos from the rear cover and the mounted grills
Regards Martin
Lovely level of detail Martin regards Phil
- Martin Hofmann
Thanks Phil for the compliments,
here are the next details for the sprockets after making some drawings for the machining of the steel rings. You also can see the first screws and castellated nuts - the screws are to long at the moment.
Regards Martin
