Tiger 1 build, mid 2010 no. 27
- Been liked: 11 times
Hi all
After my research I have started my Tiger build in due course, I plan to take my time and do it right. Well I will be, after 5 days of fitting and adjusting I finally have the hull assembled.
I must say a big thanks to all the peeps who have gone before me as all your advice and pointers on this forum have been a huge help. Plus some of the builds are spectacular.
Anyways I will post some photos in due course when things start to get interesting.
Armortek 2010 Mid Tiger 1
- Has liked: 2261 times
- Been liked: 7149 times
Re: Another Tiger 1 build, mid 2010
Make sure you do! Regards Phil
Afternoon all
Been busy today on the Tiger mainly doing welds which was quite enjoyable. I also modified the armour collar on the final drive so it fit better, plus my pannier details are fitted.
Hope to complete this side over the weekend then start on the reverse side. Quick question for the experts out there, is weld detail needed on the floor to the hull side?
Happy Easter all
Happy Easter all
I'm no expert but could you sleep at night if you don't apply the weld to those areas
Phil Woollard wrote:I'm no expert but could you sleep at night if you don't apply the weld to those areas
Haha I guess that they won't be seen
It's strangely satisfying producing all those welds init David, and they become structural to a certain extent once dry and hard, very nice keep it up. regards Phil.
- Paul Wills
- Has liked: 646 times
- Been liked: 141 times
Morning David,
Its looking good so far. As Phil aptly said, putting welds in those hidden areas is purely a personal thing. I didn't put any across the seem of the pannier floor, and this was because it would never be normal seen. Unless like some ex gunners you roll it over
Just a tip for the weld between the pannier side and the glacis plate. I used a Dremel with a small cutting disc to make a groove so I could get the weld flatter, and it helps to give the putty something to key to.
Paul.
Paul.
So been busy building away and am onto the suspension, I will post some photos soon.
Quick question to you all, I decided to look at some of the sub assemblies and was making a start on the Coppola at my bench indoors (horrible weather) I noticed the arm is drilled out for the hatch handle but cannot find one in the kit. Does it come with one as standard?
Just to note it's the late style Coppola
Thanks all
Thanks all
- Paul Wills
I think I know what you mean David, but it would be easier if you posted a photo.
Paul.
Paul.
Hi again all
Some photo updates included. I have now painted the hull in dunklegelb, suspension is well under way, half the axles pinned and flats ground. Just need to make a jig to set the angles then into paint. Have also started on the Copula making my own hatch handle, added some texturing and making some backs for the vision ports.
Re: Tiger 1 build, mid 2010 no. 27
Morning all
Been slow going of late but now have the suspension fitted to the drivers side. I am very happy with the results and now ready to start the opposite side.
The eagle eyed among you will notice that I need to invest in a mobile table of some sort as my old desk in the garage is going to become very obsolete soon!
Any pointers appreciated.
- Has liked: 4 times
- Been liked: 102 times
Hi
A lot do use a hydraulic lifting table to work on but I prefer a heavy duty roll about workbench. Bigger top area and nothing sticking out at the bottom. I put a rubber mat on top of mine and fitted 4 swivel casters instead of the standard two swivel and two fixed to make it more maneuverable in tight spaces.
Thanks John I like that idea and will have to look into that. Nice work on your Tiger so far btwJohn Heath wrote:Hi
The workbench is really heavy but so solid. Probably weighs more than the completed tank will do. Like it as it can be spun round in it's own length.
Painted the roadwheels last night. Now to weather them. Why does it seem like there's a hundred wheels to do?
- Has liked: 1564 times
- Been liked: 835 times
Hello John, that's a cracking bench....I'm making do with an old kitchen cabinet, I have reinforced it, no wheels ....now that's what I call YELLOW Lovely build...Mick
