Steves Comet build
Steve Norris
Has liked: 8 times
Been liked: 697 times
Steves Comet build
Post by Steve Norris »
I purchased this Comet at last years open day and started the build about six weeks ago.
I am very impressed with the quality and fit of parts on this kit, Having built most of Armorteks products I think this is one of their best.
Overall view.
Overall view.
Front end with added texture, bullet splash guard and reshaped vision port hinge
Back end ,again texture added repositioned bolt detail and drive housing bolts added
I must thank Stephen White for his excellent Comet build that has been my inspiration, I just wish he would put his Centurion to one side and finish his Comet.
Steve Stuart
Has liked: 258 times
Been liked: 187 times
Re: Steves Comet build
Post by Steve Stuart »
Excellent, another Comet build 8) The inspiration I need! I will look forward to watching your progress.
Tim Page
Has liked: 40 times
Been liked: 469 times
Post by Tim Page »
cats out of the bag now Steve...
Steve Norris
Has liked: 8 times
Further work on the Comet has been carried out over the past few weeks, namely the outer hull sides and the suspension components.
Overall view of the left and right outer hull sides, over 250 holes had to marked out drilled and tapped for 7ba bolts. The hull panels have been highlighted by cutting the panel lines with my Dremmel and a straight edge. I  also added some detail around the drive shaft output area using large washers and domed headed bolts.
A closer shot of the front end showing the added texture and bolt detail
Suspension added
Suspension added
Derek Attree
Has liked: 218 times
Been liked: 183 times
Post by Derek Attree »
Hi Steve
That brings back memories all those little screws :D :D :D
I didn't enjoy the kilapoise in the suspension :shock:
it gets every where :D
Chris glover
Been liked: 1 time
Post by Chris glover »
Blimey Steve, you don't half rattle through these kits! :D .I should give you my Cent hull to build up .I think you would have the arv built before I would get the tyres stuck on the road wheels :shock: .
Comets looking good!
Steve Norris
Has liked: 8 times
Hi Derek
Yes i am still finding little smears of Kilapoise all over the place, the screws took a long time to do but are well worth the effort.
Steve Norris
Has liked: 8 times
Hi Chris
Looking forward to seeing your ARV build
Chris glover
Been liked: 1 time
That's just the problem Steve, finding time to do it!.I can get in to doing detail parts it's just the overall build I can't seem to get going on :oops: .If you need a next project after the Comet let me know :D
Steve Norris
Has liked: 8 times
If I need a project I will give you a call but I am still hoping for another Panther.
Steve Norris
Has liked: 8 times
It's been a while since my last Comet update and much progress has been made. I took the partially complete hull to the recent Tankfest for a trial run and was pleased with the result although a little fine tuning of the track tensions and radio set up was required.
Since then the Comet has been returned to my workshop for completion. To insight the hull I need to carry out some more detail work and devise a method of easily removing the hull top plate and engine deck whilst hiding the fastener heads. The turret has not yet been started but should be a much easier proposition.
Anyway here's the latest update shots of the back end.
Overall view of the rear
A lot of added detail here
Tim Page
Has liked: 40 times
Post by Tim Page »
Just collected Steves A34 Comet today.
Have to get it setup with my Spectrum DX9 and then figure out some proper storage for the Panther & Comet.
Steve Norris
Has liked: 8 times
It's your Comet now Tim,
Great to meet up again and hope you enjoy the Comet
sean kerambrun
Has liked: 17 times
Been liked: 7 times
Post by sean kerambrun »
Hi Tim,
Looking forward to see what you get up to on the comet.. one of the armortek tanks I wish I had
Sean
Tim Page
Has liked: 40 times
Post by Tim Page »
Hi all, i have had a search and have found the correct lengths for the mk19 A & B set aerials, but not been able to find anything about the thickness yet.
The length of the MK19 A set aerial was at least 8 feet.
The length of the MK19 B set aerial was 25 inches.
Any suggestions as to what type & thickness of antenna i should use for my Comet?
