Bryans Quad with yet another touch of Armorpax
Ian Rodney
Been liked: 53 times
Re: Bryans Quad with yet another touch of Armorpax
Post by Ian Rodney »
Hi Dave,
Looking very good your latest upgraded parts for your Quad.
Great to read that you will have a comprehensive update set for this kit.
Cheers Ian
from Glasgow
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Hi All,
The exterior is coming on.
Dave
www.armorpax.net
Has liked: 1421 times
Been liked: 1603 times
They make such a difference the overall look of the Quad.
Love the wipers :D
Hi All,
Fuel filler surround added and top trim.
Dave
www.armorpax.net
Graham Hough
Been liked: 19 times
Post by Graham Hough »
Looking very good, nice work. Odd question maybe but are the tyres soft enough to look slightly flattened by a heavy load?
Kevin Hunter
Has liked: 598 times
Been liked: 145 times
Post by Kevin Hunter »
Someone's been a busy boy.......
Looks fab Dave, great work.
Kevin
No. You could probably stand on them without any noticeable deflection.
Hi All,
Door handle surround, rear mudguard and master for the lower stowage bin locks done.
Dave
www.armorpax.net
Hi All,
Mostly resin work this weekend, I have made the moulds and cast a set of parts for the left and right side of the quad. I have added a couple of quick pics of the sequence for working with the flat back casts for those not used to this type of resin work.
I trim the parts from the back plate with a scalpel and then, using a rotary motion, gently sand the parts to even out the back. Using a sanding block I give the edges a quick sand then glue the parts to the main body using superglue.
Dave
www.armorpax.net
sean kerambrun
Has liked: 17 times
Been liked: 7 times
Post by sean kerambrun »
Great work as usual Dave..
I wont start building my Quad until mid next year :(
Sean
Hi All.
With the 17 Pdr pre-orders packed and going out tomorrow I can turn my attention back to the Quad. New rear plate detail done and added along with rear mudguards. Mudguard fillets and support block made. Tow hitch added and new filler cap made. I'm trying to get the exterior as near finished as possible for the Model Expo at the Tank Museum.
Dave
www.armorpax.net
Looking at that last picture, could I ask that you investigate producing a replacement for the "Fuel House" (EM0323), with the correct arc so that it matches the hole in the bodywork ?
Hi Adrian,
When I have finished the exterior parts I'll cast one and reprofile it. I should have probably done that sooner but I wanted to get the model together to start working on the detail :-)
Dave
www.armorpax.net
Hi All,
Main components for the 2 Gallon Jerrycan holders done. Just need to make a right hand version of the 2 fixing straps..............and somehow closely match the left hand ones :-) Heat bending plastic in multiple directions can be a bit hit and miss.
Dave
www.armorpax.net
Hi All,
Ventilator reworked, master made for the spring catches for the bonnet etc. and I have also added the cable hook to the 2 Gallon jerrycan holder strap.
Dave
www.armorpax.net
