Tiger 1 hard target restoration ?
Has liked: 2272 times
Been liked: 7154 times
The old Tiger 1 has been brought up from the range to be used as a vehicle for the Bergepanther to recover in various scenarios.
I want to keep a lot of the battle damage as is, where possible, the near side has taken most of the hits considerably deforming the plates and top deck, the road wheels x8 are beyond repair on this side also..see pics
Re: Tiger 1 hard target restoration ?
Some interesting pics of the damage
The rnd just missed the engine
The entry point of a large calibre rnd into the engine bay
The exit point of the glasis rnd penetration
Entry point of a rnd that penetrated the glasis plate
The better side with road wheels complete except for a large cal hole in one nr the rear
The remaining road wheels after removing all those that are not repairable
The side that took most of the hits
Period interior
Period interior
Interior
Interior
Interesting patina of the interior
Interior
Interior
Scratch built engine hatch
Some progress making new parts some of which have been blown up and never recovered, like the engine hatch which just disappeared after the internal demolition charge in the lake was just a bit to big
All of the bent and twisted parts were straightened and bolted back together!
I have used ali plate for the hatch and manufactured new hinges from loader vision scope castings with 3mm galvanised wire for the grab handles, I will ad more details as I go.
One of the most menacing pics of a Tiger lying in wait I have ever seen, this pic give's me tons of inspiration! Just look at the battle damage.
i think the damage from HV rounds in this scale look very realistic
a selection of damaged road wheels, it's amazing how much punishment this model has endured.
Scratch built engine hatch test fit
Peter Silcock
Has liked: 60 times
Been liked: 33 times
Post by Peter Silcock »
Crikey Mr Woollard that is a restoration and a half. I thought my slow restoration of 1331 and 311 was difficult enough but a walk in the park next to your task! Quality of these models does indeed shine through. 1331 stood for 4 years outside but after an hours tinkering with the electrickery it burst into life and ran round the garden. Didn't have to withstand live rounds though :D
Hi Peter, tis a labour of love that we do to be sure, I'm thinking about leaving the damaged side as is but I also want to restore it all at the same time, all that character would be lost..hundreds of hours and lots of expense to get it looking this rough, modelling battle damage is more difficult to achieve than any other effect, how should I portray the weld seams?
All good fun though regards Phil
More HV damage pics
The machine gun position is in quite good shape although fragments of the softer round have found their way between the castings
Front plate, HV have entered the vehicle causing damage to the gearbox
I have replaced the damaged mid cup with an early version
The mantlet took a massive hit but did it's job very well in stopping the round
Down on the range
Tiger1 hulk, shot to running gear
HESH impact Tiger1
HESH impact Tiger1
Hesh round at Tiger1 002_0002.jpg (38.16 KiB) Viewed 5476 times
Tiger front plate after HESH ,the round cannot function as it hits the corner of the armour plates and breaks up, with little transfer of energy into the target area
Hesh round side plate, Tiger1
Hesh round as it impacts side plate , Tiger1
Hesh round at Tiger1 001_0001.jpg (43.5 KiB) Viewed 5476 times
Update
Nice shadows
Nice shadows
Standard hatches now with periscopes
I had two near side hatches so had to convert one into an off side
Sorting hatches and adding the lights
Experimental diorama photography, some old some new, nothing to do with the restoration
Tiger1 european building wrecked 014_0001.jpg (22.06 KiB) Viewed 5315 times
Tiger1 european building wrecked 015_0001.jpg (22.2 KiB) Viewed 5315 times
04_10_2004 12_08_0002.jpg (53.51 KiB) Viewed 5315 times
04_10_2004 12_08_0001.jpg (52.02 KiB) Viewed 5315 times
04_10_2004 13_43_0001.jpg (40.77 KiB) Viewed 5315 times
One of the very first Tiger1's from Armortek
Just in case you wondered what it would be like inside an Armortek Tiger1 taking hits
This round fired into the fuel tank, travelled on into the engine bay, the diameter of the round was 12 mm and contained .5 of a gram of other material for effect
Magnum heat round Tiger1 004_0002.jpg (35.74 KiB) Viewed 5295 times
Last edited by Phil Woollard on Fri Dec 02, 2016 8:30 am, edited 3 times in total.
Rounds fired into the running gear of our Tiger1 often went right through the overlapping road wheels
Hesh round at Tiger1 001_0007.jpg (33.31 KiB) Viewed 5289 times
The Tiger 2 used for firing the live rounds at the Tiger 1 hard target.
A small amount of black powder was added to the niro mix to produce a more period smoke effect.
Tiger2 firing#3 002_0004.jpg (25.74 KiB) Viewed 5085 times
You can just make out the lanyard coming from the rear of the turret.
Tiger2 firing#3 002_0003.jpg (28.26 KiB) Viewed 5085 times
Even at this scale the weight of the model provides a very stable firing platform with little recoil through the chassis.
Tiger2 firing#3 002_0002.jpg (29.12 KiB) Viewed 5085 times
Excellent shot of the gas venting sideways from the muzzel break
Tiger2 firing#3 002_0005.jpg (31.36 KiB) Viewed 5085 times
It continues.
We still have this old Tiger chassis and it's next on the list for some restoration, this is the Tiger being hit by aircraft cannon in the video.
It took a lot of searching to find this turret lid!
Mid cupola .....never found.
Note the tracks..they were the pre production resin prior to the metal type that you have in the kit now
I'm thinking about this quick fix for the missing early wheels, was this ever done in the field I wonder, I'm sure that I may have seen an old photo of maybe a single late wheel used in this way ?
Early/late wheel mix fix
