Before this was fitted all the modules where connected up on the bench and tested ,the
Audio module was set up with the Toggle switch on the transmitter, all ok
I then installed everything in the tank without disconnecting anything, but now when I
Turn on the system all I get is a hiss from the speakers and no sound or functions from
The audio module .also the hissing stops for a moment then comes back on , I have checked
All the connection but can't find anything wrong
Regards David gray
![Sad :(](./images/smilies/icon_sad.gif)
