2003 smoke unit top plate - missing holes?
Sam Hough
Has liked: 68 times
Been liked: 53 times
Post by Sam Hough »
Hello,
I'm just assembling the smoke unit and everything makes sense except where the fan would blow there are no holes. There are clearly holes to hold the fan on.
Does anybody have a picture of the smoke unit top plate?
Sam
Has liked: 1369 times
Been liked: 1567 times
Re: 2003 smoke unit top plate - missing holes?
The old style smoker with the radial fan had eight holes in a square pattern.
Four are to hold the fan and four are for the air to pass through.
The stock Armortek lid is on the left.
The one on the right is one I had made up to increase the amount of airflow.
Sam Hough
Has liked: 68 times
Post by Sam Hough »
Thanks! That is very helpful.
Mine is like the left hand one but I was expecting something like the right hand one.
Sam
If you don't get enough smoke out with the stock holes you can drill new ones on the diagonals from the fixing holes.
I wouldn't recommend enlarging the existing ones too much as they'll start to show outside the fan casing, which means you'll get smoke back inside the tank and that tends to make everything sticky.
Sam Hough
Has liked: 68 times
Post by Sam Hough »
Thanks. I need to hold off for a bit anyway as I'm going to try and get a 5v fan so it is less annoying to control from the computer.
Reaching the point where I can wire it all together soon :)
To shift the same amount of air, on a fifth of the voltage, you'll {probably} need five times the current.
Use an IRL540 instead :wink:
