SdKfz 251 build
- Has liked: 1035 times
Re: SdKfz 251 build
Mick, I love reading your posts, always brings a smile, you're so clearly enjoying yourself. Great job with the "lamp truck", looks superb. Stephen
- Has liked: 1566 times
- Been liked: 835 times
Re: SdKfz 251 build
The 251 is in for a good going over and service. The left hand idler had somehow rotated itself during the test run however, that's what testing is for.....to iron out these little probs.
Hoping to see the Flying Scotsman this afternoon....through the Cambrian Mountains.
Gorgeous weather, my washing is on the line and drying in the gentle breeze.....Mick
Re: SdKfz 251 build
The vehicle commander finally arrived.....following leave of absence....shrapnel wounds I believe....
Re: SdKfz 251 build
All quiet on the 251 front these days.... Added a few more details, the decals are made up by Pyramid Models, vinyl stick on. Looking to give my 251 a run....if only it would stop raining. Although the football has taken over for the time being....My track seems slack.....that's not rhyming slang.....Mick
- Has liked: 219 times
- Been liked: 198 times
Re: SdKfz 251 build
Hi Michael
This is a really nice build love the lamp.
Re: SdKfz 251 build
Thank you Derek and,....the lamp does work....I am enjoying the Forum posts. Some fine detailing and top quality modelling on show, well done lads.....Mick
- Has liked: 54 times
- Been liked: 689 times
Re: SdKfz 251 build
Hello Michael
A really nice work from you. I think often at your Comet. It was the same good build.
Frank
Frank
Re: SdKfz 251 build
Hello Frank, thank you for you comments. I have followed your build, very impressive. Most of my enjoyment is in the building of these superb models....I guess that's why I have over many years sold my models on....and then have regrets.....best wishes, Mick
Re: SdKfz 251 build
Hello everyone, I am enjoying the latest posts, excellent work lads. I have posted these SdKfz 251 final build photo's, one or two small details for the eagle eyed. The centre section is bolted down however, it lifts out to give access to the control 'modules'.
For anyone interested in 'dipping their toe' into this fascinating Armortek hobby, this particular model is a great starting point. A very easy satisfying build.....now if only the weather would play ball.....Mick
Re: SdKfz 251 build
The 251 is in workshops for a refit....just an excuse to play with her. While I am tinkering there are one or two improvements to make. To allow more space/movement for the smoker/switch etc, I would like to extend the wiring between the new Motion Control Module and the Smoke Unit.
Question, what gauge wire is used between these Units?. I will probably source this from the local motor accessories shop.....
I will also use small nuts/bolts to hold the wire to battery connections.....pulled apart again....ham fisted....spotted this method in an earlier post.... Mick
Re: SdKfz 251 build
I had intended to fit the 'smoker' during the Autumn however, with the changeable weather I started last week. This smoker certainly is the 'bees knees', very impressive. I added a 90 degree copper bend to obtain more space. There is a surprising amount of room in the engine compartment....the batteries are located on the two white felt pads, the speaker is in the rear compartment...... Mick
- Been liked: 53 times
Re: SdKfz 251 build
Hi Michael,
I've been following your build on Sdkfz 251.
Like the big search light!…could take longer lasting Duracell batteries!
Ian
Ian
Re: SdKfz 251 build
Thank you for your post Ian. The Amortek kits are a pleasure to build, and great fun....
Re: SdKfz 251 build
Now....regardless of the 'advice' never to run your precious Armortek models on stoney ground....in a moment of age related madness....
