Metric flat brass bar
- Has liked: 2508 times
- Been liked: 443 times
I’m looking for some flat brass sized 15 x 10mm about 400mm long, anyone know where I can get some, it’s readily available in Germany but the postage for some strange reason is extremely high
- Has liked: 1024 times
- Been liked: 2094 times
Re: Metric flat brass bar
For brass, I use MACC Models who may have what you need:
https://maccmodels.co.uk/materials-meta ... 21-12.html
Or, Metals 4 U:
http://www.metals4u.co.uk/brass/flat/c25
Final option might be:
http://www.mkmetals.co.uk/
I've used all of them with success.
For completeness, I've also used Aluminium Warehouse for Ally. They're very good at cutting sizes to order:
http://www.aluminiumwarehouse.co.uk/
Normal health warning - I'm not endorsing any of them and "there are other suppliers out there".
All the best.
Or, Metals 4 U:
All the best.
- Tim Page
- Has liked: 40 times
- Been liked: 469 times
Hi all, MK metals are less than 10 miles rom me if anyone needs stuff collecting etc.
- Has liked: 258 times
- Been liked: 187 times
I have found another supplier of metals cut to size, namely Rapid Metals, http://www.rapidmetals.co.uk/. They are based in Coventry and Redditch and offer a helpful and friendly outlook.
- Has liked: 5 times
- Been liked: 682 times
My local supplier has 16 x 10 mm on his list of available brass bar sizes. Usually sells in 3 metre lenghts but often has offcuts. I AM BASED IN IRELAND THOUGH. I can check to see what he has and cost. Can also check postage. Do you need a single length or can it be cut. This might affect postage.
John, thanks for the offer however I have already bought some from Milton Keynes Metals the bar arrived the following day the problem is that I couldn’t find metric size and had to buy Imperial 5/8 x 3/8 which is 9.5 x 16mm not quite what I wanted but I can work with it.
- Has liked: 1421 times
- Been liked: 1603 times
A personal bugbear of mine is when you think you're buying metric and get sent the closest imperial size. 5/8" for 16mm is quite a standard substitution.
If it was oversize you could remove material but if it's undersized you're stuffed.
I imagine what my supplier has, if measured is probably 9.5 mm also since other dimension is also 16mm.
- Been liked: 3501 times
Hi Gents
Brass bar is almost entirely still imperial. What little metric bar is available is offered at a premium price. Most ally squares and flats etc are similar. If you are offered metric, it will almost always be the nearest imperial size, which can often be little smaller.
