Proxxon Chop Saw (KGS80)
Has liked: 1475 times
Been liked: 1674 times
I know there are quite a few fans of the Proxxon tool range here, so I'm looking for advice on the KGS80.
I was using it to cut some aluminium angle yesterday and couldn't find a cutting method which didn't turn the detached piece into a projectile. Appropriate as I'm making parts for a tank :D but disconcerting nevertheless :shock:
I'm wondering if some foam along the back of the baseplate may act as a back stop and absorb their energy.
The other annoyance is that the saw blade teeth seem to catch the part as it disconnects, causing gouges of varying sizes. I would be interested to know if anyone has this saw and whether the resin blade would be better than the toothed blade :?:
I'll only be using it to cut brass and aluminium.
Has liked: 1038 times
Re: Proxxon Chop Saw (KGS80)
Adrian, I'm very much a fan of Proxxon kit. I can't help you directly as I use the MBS 240E Micro Bandsaw, which works brilliantly with the 24 tpi blade. I do also use the Long Necked Grinder with a Corundum disk and that is very powerful. Looking at the KGS80, it comes with some very large toothed blades so I wonder whether your solution is to try the corundum disks that are available for it, or find a fine tooted blade from another manufacturer (I believe Axminster have some other options.
All the best
Thanks Stephen. I'm going to need a bigger workshop :lol:
I know you mentioned the band saw in your builds, but I thought the chop saw might be more robust for cutting bar stock for the lathe, so went with that instead.
I've ordered a resin disk from Amazon to try, so hopefully Prime will get it to me before the Easter break :)
Al Aldrich
Post by Al Aldrich »
When using a chop saw or circular saw to cut aluminum, I use a carbide tipped blade
and install it backwards this way you're not taking such a big bite from the teeth.
You also don't want to be heavy handed, let the blade do the work. Been doing this
for years. Yes, a band saw works best. For my friends that don't have the shop I have
I have taught them safe ways to do things with what they have. AL
Uwe Gerstenmayer
Been liked: 72 times
Post by Uwe Gerstenmayer »
Hi Adrian,
I'm working with the KGS80 as well for a long time now. Some hints are
- the KGS is very sensitive to feed ! Slow feed torwards the cut through is mandatory
- good experience with the 36 tooth hard metal blade on thicker material
- for thiner profiles I use the 63,0 mm HSS blades from Knupfer (80 teeth), suitable for Proxxon.
- I try to grab very small parts with a long "Pinzette"
This Thursday I'll be on the Intermodellbau in Dortmund and will have a look for some good blades as well. I'll let you know when I've found a good source :wink:
Greetings from Cologne,
Uwe
1:16 Models: Kingtiger
