King Tiger 2009
Peter Dierckx
Been liked: 16 times
Re: King Tiger 2009
Post by Peter Dierckx »
finished the ventilatorcase, rounded it like the real one. Gives a better result, but that's my opinion
"There are no atheists in foxholes" isn't an argument against atheism, it's an argument against foxholes
Fredrik Jorgensen
Been liked: 1 time
Re: King Tiger 2009
Post by Fredrik Jorgensen »
Really nice work there.......thats probably the pickiest jobs on th KT.
Thank god i had mine 3d printered :)
Keep the work up
Freddie
Edward Earp, Jr.
Been liked: 1 time
Re: King Tiger 2009
Post by Edward Earp, Jr. »
HELLO PETER !!! WHAT SIZE DRILL AND PIN DID YOU USE TO REINFORCE THE SUSPENSION ARMS ?
INFORMATION WILL CERTAINLY BE APPRECIATED !! THANK YOU, ED EARP, JR.
edearpjr@austin.rr.com
Peter Dierckx
Re: King Tiger 2009
Hi Edward,
I drilled the holes with a 3.5mm drill and used nails with diameter of 3.3mm. I secured the nails with loctite
Paul Morris
Been liked: 68 times
Re: King Tiger 2009
Post by Paul Morris »
Hi Edward.
Try a 3mm drill and 3mm roll pin, that's what I always use.
Cheers Paul. :wink:
01524 720977
