Derek's slow build of 004 / 2014 issue
Derek Attree
Has liked: 218 times
Been liked: 178 times
Post by Derek Attree »
Hi Guys
So with the Comet getting close being finished I have been playing
with the first parts of the half track and that has been the wheels.
Some of these are cast as in the original kits. But Mark has also made
the thinest ones machined out of solid.
These should be much stronger than the original kit cast version. Image
This is the type machined from the soild and I have removed the slight machining marks by
careful use of a dremel and sanding drum.
The surface will be textured using high build upol primer to look like a cast wheel which
is like the real thing.
Below are the cast wheels and these are a good strong and much thicker section and have
great detail.
This picture shows all the wheels and the sprockets getting the first etch primer coat.
All of this is so I can glue the tyres on this at the same time as I do the Comet tyres.
I also have primed the sprocket and again this has had re-work from the original kit.
I hope you like. I have wanted one of these since the first issue of this model
and I am pleased to have gotten this one from the small batch of new kits.
I have to say it is an impressive kit and its good to see Mark has upgraded things he felt
needed attention.
First class company
Derek Attree
Re: Derek's slow build of 004 / 2014 issue
Hi Guys
A bit of progress and a couple of photos
Derek Attree
And a couple more
John Fitzsimons
Has liked: 5 times
Been liked: 567 times
Post by John Fitzsimons »
Very nice Derek. I would love to pick up one of these kits sometime. Looks impressive when complete.
Derek Attree
Hi Guys
I have been doing a bit on the half track,
Here are the sprockets these are redigned from the first batch of kits
and seem to be very strong.
Derek Attree
Hi Guys
This is the winch which has been a nice build.
Derek Attree
Hi Guys
The front end I have made some ajustments to this so it is
now to my licking including silver soldering the joints and the track rod ends.
Derek Attree
Hi Guys
The last two pictures for now I have been making the tracks as well and its my
plan to have this at Ally Palace for the ME show in January.
Derek Attree
Hi Guys
Been doing a bit more on the winch Cable fitted and
the rods that stop the cable poping off the drum.
Hope you like this has been a fun item to build
Derek Attree
Guys
The rods that stop the cable coming off the drum are
silver steel soldered to a brass angle I had to machine from solid
as I could not find any thing off the shelf the right size.
it is worth doing as the real thing has them and the cable
was springing off the drum all the time.
the cable is 2mm diameter and came from B&Q DIY stores here in England.
Derek Attree
Guys
One other thing I have done is to re work the tow hook as to be more like the original.
This is a work in progress as there is more details to add like handels and the chains to hold the pins in place.
It now works in the 3 axis like the real thing.
Derek Attree
Hi Guys
With all the tracks and stearing fitted.
The arms on the stearling are silver soldered in to the knuckel for extra strength.
That is all for now and a Happy Christmas to all.
Ian Rodney
Been liked: 53 times
Post by Ian Rodney »
Looking good Derek,
Coming along very nicely your Half Track, like the tow hook and stearing unit and tracks on now.
Have a good Christmas & New Year……..
Cheers Ian
Has liked: 119 times
Been liked: 753 times
Derek,
Fantastic work on the SDKFZ7. Looking great. I too would like to find one of these kits. Top of my list. Keep us posted on your progress. Looks really good with tracks on. Are you making the standard troop carrier or flak-track? Happy holidays.
Derek Attree
Hi Bob and Ian
Thanks for the feed back.
Rob its going to be a standard prime mover.
