Sd.Kfz.7/1 and 20mm Flakvierling 38
phil fitzpatrick
Been liked: 223 times
Re: Sd.Kfz.7/1 and 20mm Flakvierling 38
Post by phil fitzpatrick »
Striped it down a bit and started on my electrics,motors first and a few other bits
phil fitzpatrick
Winch motor fitted
Derek Attree
Has liked: 218 times
Been liked: 178 times
Post by Derek Attree »
Hi Phil
Coming along really well.
Will the drive motors go in with out seperating the chasis ?
It looks a bit of a tight fit. :shock:
phil fitzpatrick
Thanks Derek,
Yes the motors went in easily,Ive got some more photo's on my camera
that I haven't got round to getting on the computer.
If you have your motion pack aswell before you start,it is a good idea
to fit the little bush that supports the end of the motor shaft,into
the gear box recess at the early chassis stage.
Otherwise you end up balancing it on the end of your finger and poking it through the
hole in the chassis.
mine needed a bit of emery paper for a better fit.
Also the stearing servo might be easier fitting at the chassis stage.
phil fitzpatrick
Drive Motors fitted
phil fitzpatrick
Used part of the battery tray for my speaker
phil fitzpatrick
Stearing servo and linkage
phil fitzpatrick
Made my own battery tray to sink as low as possible.
phil fitzpatrick
Made some Sub Decks for my electronics,just enough clearance.
phil fitzpatrick
My battery set now sits nice and low and room for my power supply.
phil fitzpatrick
Power supply fitted on top of battery set,access to power button through
engine grill.
phil fitzpatrick
The rest of the electrics sitting on the sub decks,the exhaust system
still to go in,just had to take the screws out of the module covers,
clearance is nill between deck.
The clearance between middle sub deck and winch top bolts is a piece of 180
wet and dry :)
The black cable protector disguises all the bright colours.
John Fitzsimons
Has liked: 5 times
Been liked: 597 times
Post by John Fitzsimons »
Nice neat layout. Great to see this part.
phil fitzpatrick
Thanks John :D
I might spray just the one edge of the speed controller and amplifier module,with
the dark yellow,so that it doesn't stand out so much.
Has liked: 119 times
Been liked: 753 times
Phil,
Your SDKFZ 7 is looking great. Very nice install with the electronics. Are you planning on the Armored cab? Beautiful job on the rear deck. I'd love to build one of these someday. Fantastic work as always.
