Castellated Nuts per tank
Has liked: 1365 times
Been liked: 1564 times
Can anyone let me know how many castellated nuts are required for a Late Tiger 1 :?:
I'll be fitting Steve's bump stops, so that's twelve, plus the rear tow hitch needs four, but I'm not sure if are of the any other fittings require them :?:
John Fitzsimons
Has liked: 5 times
Been liked: 629 times
Re: Castellated Nuts per tank
Post by John Fitzsimons »
That's all I used unless you want to start on the interior. Used a few inside.
David M Wilks
Has liked: 427 times
Been liked: 21 times
Post by David M Wilks »
I found another 10 are required for the front hull fillets, but you have to recess the plates ,there are some good photos from the Vimoutiers and Samur Tigers around. Dave W
Thanks both.
I was at the Vimoutiers Tiger on the 3rd June, so have some photos of the fillets :D
