2013 King Tiger
Roger Sleep
Been liked: 41 times
Re: 2013 King Tiger
Post by Roger Sleep »
Thank's you guys for the reply post on how to achieve accurate weld's on our tank's, as this will be my 1st attempt, it has given me more scope on how to go about it,and material's to use
Tankyou Rog
yves mouton
Been liked: 741 times
Re: 2013 King Tiger
Post by yves mouton »
Hello,
I'am also use milliput ( the yellow one )
very easy to work with.
regards Yves
Roger Sleep
Re: 2013 King Tiger
Re-think on sprockets:
Re-worked (was not happy with the way they where looking), the sprockets, had to strip them down and sand off the base coat and re-primed the hidden areas (Nut and bolt area).
Bought new 6BA Nuts and Bolts re-fitted sprocket rings so it replicates the real King Tiger.
All ready for a cote of etch prime.
phil fitzpatrick
Been liked: 223 times
Re: 2013 King Tiger
Post by phil fitzpatrick »
Nice to see you Happy in your work Roger :)
Looks well worth your efforts.
Roger Sleep
Re: 2013 King Tiger
Hi Phil thank's for the comment :) Can't wait to get a coat of base coat on it, still struggling trying to do the wheel marathon trouble is I think I could probably run the marathon quicker for how long it's taking (I'm a bit picky) :)
Rog
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Re: 2013 King Tiger
Post by Dennis Jones »
Hi Roger,
Hate to be picky but shouldn't the locking tabs be on the outside of the wheel rim.
Dennis.
John Fitzsimons
Has liked: 6 times
Been liked: 817 times
Re: 2013 King Tiger
Post by John Fitzsimons »
Dennis is right. Also the nuts should face outwards rather than the boltheads. :D
Nuts and bolts wrong way round on the back also. There would have been locking tabs on the inner side also but kit only includes the set that could be seen. nuts face outwards both sides.
Excellent job removing those machining marks.
Dave Boller
Re: 2013 King Tiger
Post by Dave Boller »
Yep, the locking tabs go on the sprocket outside, as do the nuts. But Roger, you should probably get yourself a good photo of the wheels to follow along with. The bolts can run in opposite directions on those for the KT.,and you need to know which ones go which way. You can probably find some pictures right here on this site, in the KT thread.
1/6 Armortek: Panther,KingTiger. 1/6 FOA: Tiger-1,251 Halftrk. 1/6 ArmorHobbies: 250 Halftrk("GRIEF"). 1/6 DML: Kubelwagon,Kettenkrad. 1/16 Trumpeter KingTiger. 1/24 Tamiya: Tiger-1,Panther.(& a countless host of others too small to mention)
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Re: 2013 King Tiger
Post by Kent Wiik »
Dennis Jones wrote:Hi Roger,
Dennis.
Hi all,
In my eyes Roger has got it right.
The T2 sprocket had the sprocket ring bolts from the outside in with the lock bars at the inside.
The T1 sprocket had the sprocket ring bolts from the inside out with the lock bars at the outside.
It´s all in the details!
Roger Sleep
Re: 2013 King Tiger
Sprocket Detail
Many thank's for all your comment's here are some of the pic's below where i got my information.
Regards Roger
Bovington King Tiger
Detail of sprocket's on the King Tiger La Gleize in Belgium
John Fitzsimons
Has liked: 6 times
Re: 2013 King Tiger
I know you are working fast. Glad you did'nt change anything. A few other King Tigers might need to be changed though.
Roger Sleep
Re: 2013 King Tiger
Update on Drive Sprocket's
Nice to see these done again after my first attempt which was wrong. :D
Etch primer applied after final assembly
Base coat applied
Base coat applied
Dave Boller
Re: 2013 King Tiger
You're right. Looks like the tabs and nuts are the other way. But I know I've seen it done many times right here on this site that way. Good catch Roger. But you do have to be careful when looking at post-war vehicles. A lot of error creeps into them during all the years since. Parts being modified, replaced with make-shift components, some discarded all together; parts being re-installed the wrong way. You need look no further than the phoney paint-jobs many now have to know how much attention to detail was given them. It is tempting to want to use newer, color photos of them, especially given the poor quality and detail of war-time photos, but those really are "straight from the horses mouth" so to speak.
Roger Sleep
Re: 2013 King Tiger
Thank's Dave for your kind comment's on being careful on post war pics, like you said it is tempting, but i will be on my guard and hopefully i will get them right, but some times i will probably get them wrong, but that's when it's nice when you guy's comment and discuss the right and wrong's in putting thing's together
All the best cheers Roger
Kent Wiik
Has liked: 6 times
Re: 2013 King Tiger
Post by Kent Wiik »
Hi Roger,
Yes be careful using post war photos as template as well as museum stuff.
Always try to find war images and only use the other ones as hints.
Here is a link showing the T2 sprockets as they looked like WW2.
http://www.network54.com/Forum/637977/t ... aintenance
BTW, don't forget folding up the lock bar ends to the nuts.
The bars want be of any use otherwise... :roll:
