British Larkspur and Clansman Flexible Antenna Bases
Mike Stannard (toyrific)
Post by Mike Stannard (toyrific) »
Hi Guys
Having seen the post by Stephen White and others on British antenna bases I figured I would make them. I like Stephen have some signaling experience, two years as a RSWO, Regimental Signals Warrant Officer, 1976-78. Unfortunately my memory is not as good as Stephen's. The mention of the C42 and B47 brought back some memories, one thing I never got the hang of was Morse Code, had to rely on my signal corporal that could read and send it like a book.
Anyway here are my new offerings that may interest some of you. The Larkspur and Clansman antenna bases, these are made of flexible rubber the same basic design as my German antenna base. Some detail is lacking such as the wing nut screw which to make as per the real one would require is being cast in brass or machined, so I am leaving it to those that want this detail to make their own. The round metal base that holds the real one with 6 bolts is also missing from the parts at the moment. This I will have photo-etch if there is enough demand. Another detail that is missing on the larkspur is the small metal washer near the top, again held by 6 screws, and the earthing strap. Here the washer could be photo-etched and small pan head screws are available, the head diameter in 6 scale would be around .040", the smallest I can find is .053" which will likely work. But for me to add this detail would be expensive.
Here are the current prices for the antenna bases. You may order now at a pre-production price of $25.00 without the round photo-etched base. If I get enough orders I will make the photo-etched base and those that order at the pre-production price will get the round base at no extra charge. If I make the round base the regular retail price will increase to $30.00. Pre-production offer available until September 20, 2013.
I have made a mold with one of each antenna base to produce the samples shown, if the demand is high enough I will make a multiple yield mold, otherwise I will fill orders from the single mold I have.
BT01-01-A British Larkspur Flexible Antenna Base $27.50
BT02-01-A British Clansman Flexible Antenna Base $27.50
Antenna Rod not included, this can be made from 3/32" brass tubing found in most hobby shops.
Mike
Has liked: 1024 times
Been liked: 2094 times
Re: British Larkspur and Clansman Flexible Antenna Bases
Perfect Mike. Great timing and a service to us all. Two Larkspur bases for me please. Hope the take up is good. Keep up the good work. The Clansman bases will be great for the Armortek Chieftain and Challenger...........
But sadly, not for the Famo. S
Hi Stephen
I have never seen a picture of the Famo with a antenna mounted, but it's likely it would be the standard German antenna base that I offer.
Mike
Steve Stuart
Has liked: 258 times
Been liked: 187 times
Post by Steve Stuart »
Perhaps 'Scammell' might be more appropriate?
Might be an idea instead, Mark?
Last weekend I went to The Great Dorset Steam Fair, where there were several in attendance. Not to mention a couple of Stalwarts with their tanks doing a sterling job as well. Diamond Geezers..... :D
