6th Scale Icons Reintroducing Resin Parts and New Ones
Mike Stannard (toyrific)
Post by Mike Stannard (toyrific) »
Hi Guys
Several years ago I introduced some of my parts as resin castings to make them more affordable to those with a limited hobby budget. Unfortunately at the time I was not able to continue producing them as the resin casting was taking to much of my time. I now have a assistant that is proficient in casting resin, to keep him busy I am reintroducing those resin parts and plan on making more.
At the moment I have molds which were made years ago for 25 different sets and these are available for order now. However some hand tools may be delayed as I have run out of the small tool clamps and have to wait until I restock.
I am planning on making another 21 sets of parts in resin, which will include my latest Tiger 1 and 2 late muzzle brake. These parts will be made depending on demand, as it will cost a few hundred dollars for molding material. I cannot invest in making the molds unless I get some tentative orders for the new parts. Please send in your tentative orders for these new parts, no payment required. You will only need to pay once parts are made and ready to ship and I send you a invoice.
See quick guides of the resin parts below. These are the only references for the parts I will publish for some time. Once I have established which parts will be finally made I will publish a new section of resin parts in my catalog and price list. A price list is attached below.
Note I am only making resin parts of my original metal parts and do not intend to make any new resin only parts already offered by Panzerwerk or Armorpak.
As the resin parts are direct copies, some modified slightly, of my metal parts you will get the same quality and detail as my more expensive metal products. You can order most parts as just resin castings or with fittings were available.
Test shots from the molds already made. All molds are good.
Quick Guides
Products available.
Products to be made.
Here a few samples of the resin cast parts already made.
Price List.
Resin Cast Parts. All as Kits Only
RC001 Hammer Resin Cast $5.00
RC001-01 Hammer Resin Cast with Photo-ecthed Clamps and Fittings $12.00
RC002 Large Axe Resin Cast $5.00
RC002-01 Large Axe Resin Cast with Photo-ecthed Clamps and Fittings Most Tanks and AFV’s $13.00
RC002-02 Large Axe Resin Cast with Photo-ecthed Clamps and Fittings Late Pz IV $13.00
RC003S Short Handle Shovel Resin Cast $5.00
RC003S-01 Short Handle Shovel Resin Cast with Photo-ecthed Clamps, Fittings & WM part. T1 $15.00
RC003L Long Handle Shovel Resin Cast $5.00
RC003L-01 Long Handle Shovel Resin Cast with Photo-ecthed Clamps, Fittings & WM part. Early $15.00
RC003L-02 Long Handle Shovel Resin Cast with Photo-ecthed Clamps & Fittings. Late $12.00
RC004 Wire Cutters Resin Cast $5.00
RC004-01 Wire Cutters Resin Cast with Photo-ecthed Fittings and working wing nut clamp T1 $10.00
RC004-02 Wire Cutters Resin Cast with Photo-ecthed Clamp & Fittings. Most tanks and AFV’s $10.00
RC004-03 Wire Cutters Resin Cast with Photo-ecthed Fittings. SD250 $12.00
RC006 Square Head Hammer Resin Cast $5.00
RC006-01 Square Head Hammer Resin Cast with 2 Photo-ecthed Clamp s $11.00
RC007 PIck Axe Resin Cast $5.00
RC007-01 PIck Axe Resin Cast with 2 Photo-ecthed Clamp s $12.00
RC007-02 PIck Axe Resin Cast with 2 Photo-ecthed Clamps & Fittings SD250 $13.00
RC008 Small Axe Resin Cast $5.00
RC008-01 Small Axe Resin Cast with 1 Photo-ecthed Clamp $8.00
RC008-02 Small Axe Resin Cast with Photo-ecthed Clamp and Fittings SD250 $10.00
RC009 Panther Tow Cable Eyes Set of Two Resin Cast $10.00
RC009-01 Panther Tow Cable Eyes Set of Two Resin Cast with Wire Cable $12.00
RC010 PzIV and Stug C Shackles Set of 2 Resin Cast $10.00
RC010-01 PzIV and Stug C Shackles Set of 2 Resin Cast with Photo-etch Bracket $15.00
RC011 PzIV and Stug Wrenches Set of 2 Resin Cast $10.00
RC011-01 PzIV and Stug Wrenches Set of 2 Resin Cast with Photo-etch Clamps $15.00
RC012 PzIV and Stug S Shackles Set of 2 Resin Cast $10.00
RC012-01 PzIV and Stug S Shackles Set of 2 Resin Cast with Photo-etch Clamps $15.00
RC013 PzIV and Stug Tow Cable Eyes Set of 2 Resin Cast $10.00
RC014 SD250 Antenna Base Resin Cast $5.00
RC015 SD250 Tow Hook Resin Cast $15.00
RC016 SD250 Pike Resin Cast $5.00
RC016-01 SD250 Pike Resin Cast with Photo-etch Fittings $10.00
RC017 SD250 Pry Bar Resin Cast $5.00
RC017-01 SD250 Pry Bar Resin Cast with Photo-etch Fittings $10.00
RC017-02 Late Type Pry Bar Resin Cast with 2 Photo-etch Clamps Many Light Tanks and AFV’s $12.00
RC018 SD250 Jack Resin Cast $5.00
RC018-01 SD250 Jack Resin Cast with Photo-etch Bracket $13.00
RC019 Tiger 1-2 and Panther Track Tow Rope Eyes Set of 2 Resin Cast $10.00
RC019-01 Tiger 1-2 and Panther Track Tow Rope Eyes Set of 2 Resin Cast with Wire Cable $12.00
RC019-02 Tiger 1 Early Track Tow Rope Set Resin Cast Tow Eyes Wire Cable & WM & PE Parts $30.00
RC019-03 Tiger 1 & 2 Late Track Tow Rope Set Resin Cast Tow Eyes Wire Cable & WM & PE Parts $25.00
RC020 Tiger 1-2 Tank Tow Rope Eyes Set of 2 Resin Cast $12.00
RC020-01 Tiger 1-2 Tank Tow Rope Eyes Set of Resin Cast with 2 Wire Cables $15.00
RC020-02 Tiger 1 Tank Tow Rope Set Resin Cast Tow Eyes, Wire Cables.WM &PH Parts & C/Rod $40.00
RC020-03 Tiger 2 Tank Tow Rope Set Resin Cast Tow Eyes, Wire Cables.WM &PH Parts & C/Rod $40.00
RC020-04 Jadgtiger Tank Tow Rope Set Resin Cast Tow Eyes, Wire Cables.WM &PH Parts & C/Rod $40.00
RC021 Tiger 1 U Shhackles Set of 4 Resin Cast $20.00
RC022 Tiger 1 Turret Ring Guard 6 Parts Resin Cast $30.00
RC023 Tiger 1 Driver and Radio Op Hatches Resin Cast with Photo-etch Parts $70.00
RC024-01 Tiger 1 Escape Hatch Dec 42-Jul 43 (Beveled hatch plate with 3 bolt hinge base) $40.00
RC024-02 Tiger 1 Escape Hatch Jul 43-Feb 44 (Flat hatch plate with 3 bolt hinge base) $35.00
RC024-03 Tiger 1 Escape Hatch Feb 44 to End (Flat hatch plate with cut 2 bolt hinge base) $35.00
RC024-04 Tiger 1 Escape Hatch Feb 44 to End (Flat hatch plate with 2 bolt hinge base) $35.00
RC043 2 cm Ammunition Box Resin Cast. Flak 38 Trailer, SdKfz 10/4 $6.00
RC043-01 2 cm Ammunition Box Resin Cast with Brass Hinge & Photo-etched Box Clamp $10.00
New Resin Parts Pending Production
RC025 Tiger 1 Loaders Hatch Resin Hatch and White Metal and Photo-etch Parts $45.00
RC026 Tiger 1 Turret Air Vent Basic Resin Cast 2 Parts with 6 Brass Spacers and nuts and bolts $15.00
RC027 Tiger 1 and 2 Late Turret Air Vent Basic Resin Cast 2 Parts $10.00
RC028 Tiger 1 Early Loaders Periscope Resin Cast 2 Parts $12.00
RC029 Tiger 1 and 2 Late Loaders Periscope Resin Cast 2 Parts $12.00
RC030 Tiger 1 and 2 Cupola Periscope Tops and Armored Covers Set of 7 Pairs Resin Cast $50.00
RC031 Tiger 1 Early Pistol Port Resin Cast $6.00
RC032 Tiger 1-2 and Panther C Shackles Set of 2 Resin Cast $12.00
RC032-01 Tiger 1-2. Jadgtiger C Shackles Set of 2 Resin Cast with W/Metal and Photo-etch Fittings $25.00
RC032-02 Jadgpanther C Shackles Set of 2 Resin Cast with Photo-etch Fittings Assembled $45.00
RC032-03 Struumtiger C Shackle Set of 1 Resin Cast with Photo-etch Fittings Assembled $15.00
RC033 Tiger 2 U Shackle Set of 4 Resin Cast $30.00
RC034 Tiger 1 and 2 Heater Prt Cover Resin Cast $5.00
RC035 Tiger 2 Rear Acces and Cold Start Cover 2 Resin Cast Parts and 2 White Metal Parts $15.00
RC036 Tiger 1 & 2 Muzzle Brake. Resin and White Metal Cast Parts and Photo-etch Parts $55.00
RC036-01 Tiger 1 & 2 Muzzle Brake. As RC036 with Armortek Barrel Adaptor $70.00
RC036-02 Tiger 1 & 2 Muzzle Brake. As aRC036 with Barrel Rifle Plug $100.00
RC036-02 Tiger 1 & 2 Muzzle Brake. As aRC036 with Barrel Rifle Plug & Armortek Barrel Adaptor $120.00
RC037 Panther and Jadgpanther Periscope Tops Resin Cats $5.00
RC038 Panther and Jadgpanter Rear Access Covers Set of 4 Resin Cast $15.00
RC039 Panther and Jadgpanther U Shackle Set Of 4 Resin Cast $35.00
RC040 Panther Periscope Tops and Armored Covers Set of 7 Pairs Resin Cast $50.00
RC041 Blowtorch Resin Cast with 2 White Metal Parts $15.00
RC041-01 Tiger 1 Blowtorch Resin Cast with 2 White Metal Parts and Photo-etch Tray $25.00
RC041-02 Tiger 2 Blowtorch Resin Cast with 2 White Metal Parts and Photo-etch Tray $25.00
RC041-03 Panther Blowtorch Resin Cast with 2 White Metal Parts and Photo-etch Tray $25.00
RC042 Pz II Late Tow Hook Set of 2 Resin Cast $10.00
Mike
