Ultimate Panther/Jagdpanther Build
- Been liked: 1661 times
Re: Ultimate Panther/Jagdpanther Build
recoil is a nice extra to fit michael, i wish i had done mine, i might even go back to it, well done worth the effort, regards simon.
- Has liked: 5 times
- Been liked: 682 times
Looking forward to seeing finished piece in action.
- Been liked: 223 times
Hi Mick
Nice to see your progress on your recoil,I like the weathering on
your mild steel angle
How did you do that
How did you do that
- Has liked: 1564 times
- Been liked: 835 times
Thanks for your observations, Simon, John and Phil.
Ensconced in the garage again.....fortunately the Sun was blazing away through the doors so, not quite so cold. Very time consuming......hand filing. I'm scared to death I will file away too much metal on the gun mount. I am almost there though....the barrel pivot is moving freely.
The mild steel angle bracket,I chose because the extra weight acts as a counter balance to the long gun barrel. A little bit of lateral thinking The Sun has now gone down so, it's inside for tea and crumpets.....Mick
The mild steel angle will be cut to length, when I have fitted the servo.....
A few photo's of my working area in the cold garage.......band saw sits on the washing machine, bench vice on the cleaning implements cupboard, spray booth and grinder on the workbench.....can't use the workbench to easily, as the tank trailer is in the way
Dry fit of the recoil basics.....so far so good.
Hi Mick
The recoil is looking good , you are making progress all the time keep up the good work and keep posting your progress.
All the best ,,,,,, nick
Hello Nick, thanks for your comment. I know some of my photographs are incidental to building tanks.....however I include them to show that you can build to a good standard with minimal tools and space.
I have lifted the upper hull onto wood blocks to allow space for fitting the elevation and slew motors. Not looking forward to cutting out the recoil servo 'location' in the steel angle bracket. I may just get away with fitting the servo upright.....will have to wait and see......Mick
Hi Mick
I think your recoil will be well worth all your efforts when you see
it all working with the sounds.
Your garage/Tank Depot looks well organised,but what is the bag of cement for?
Hello Phil, thank you for your reply. The cement is there for a small wall I have to build in the garden......it was one of those comments ie, 'you need to build a small wall there'.....
Now for your next quiz, ( observation ) I have hidden a 'rubber eraser' in the last photo, to erase my mistakes......can you spot it ???
Best wishes Phil....Mick
- Has liked: 1421 times
- Been liked: 1603 times
You should have given it a coat of primer
If you need any help with the electronics for the recoil I can provide any of the bits from the current system.
Well spotted Adrian, thank you also for your kind offer reference the 'recoil system'. Gill had mentioned that you may be able to offer help.I will most certainly bear that in mind.
At the moment the conversion is going well. However, my modelling history is one of, (if it can go wrong, it probably will)
Thanks again Adrian.....best wishes, mick
Question time, I have started a dry fit of the Elevation and Slew motors. I have assumed that the Slew/Turret motor is one and the same on the Jagpanther.
For the main gun I have two of the same type G38 motors. One motor fitted with a plug, one motor without a plug.
So, I have connected the Slew/Turret motor to the lead on the Auxiliary Module as the plug and socket match each other.
The other motor has a lead with two 'spades' but no plug/socket.
The turret sub loom with the two limit switches has two plug/sockets. One plug/socket has yellowgreen/black leads. The other plug/socket has black/black leads. I am unsure which of these plug/sockets to use.????
My instruction book shows the sub loom, with coloured leads, that do not match my sub loom.
- Been liked: 3501 times
Hi Mick
Both your motors should have had identical plugs on them. The slew motor connects directly to the aux module, as you have done. The elevation motor connects to the matching socket on the end of the turret sub loom (the one with two black cables). We can send you a plug.
Thanks for your prompt reply Mark....it was the missing plug which threw me, I know that as the plugs/sockets are different you can't get them the wrong way round, thanks again......Mick
