King Tiger Porsche Turret Build
having not seen a porsche turret build on here i will post mine, i have a vehicle in mind ,the photo of three kingtigers on a firing range, mailly le camp i think, the tank closest to the camera which seems to have a good camo and something to go on, and with the dreaded zim, regards simon.
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: King Tiger Porsche Turret Build
Post by Steve Norris »
Hi Simon.
Great to see that your next project will be a king tiger, i am realy looking forward to what you do with this build. Just started my own Henshel turret KT so i should have plenty of inspiration following your build.
thanks steve for the praise, please post your build, they are always top notch posts and supremo building, regards simon.
i know we have seen this stage of build before, but the fit of this kit is superb, the rear hull plate is already angled at the top edge, so no adjustment there, having built one before some filing was required, this one just falls together, i am looking forward to the zimmerit and the challenge of scale detail, anything of interest i will post, but we have seen most of the basic stuff on earlier builds, regards simon.
slowly working away on the build. also fitted the aerial on the jagdpanther, made some alterations on the air vents to square the corners off and round the profile,fitted mike stannards grills, welds and cast numbers to add, regards simon.
Steve Norris
Has liked: 8 times
Hi Simon.
Good steady progress being made there.
Funny you should show your grills as these are the parts I am working on myself at the moment, I am making them myself so when finished I will post some pics (if I can get them to look anywhere near as good as Mikes examples I will be very pleased).
Keep up the good work
thanks steve, i did make my own on the jagdpanther both fan and heater grills,the mesh i used was slightly finer and seemed to look o.k., i had these two already so used them, regards simon.
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Hi Simon
Good to see some new photos. Watching your's and Steve's builds with very much interest. Always enjoyable and educational. :)
yves mouton
Been liked: 741 times
Post by yves mouton »
Hello Simon,
I will follow this KT build,
do you still have the place to set this KT on your display ? :roll:
ps: the jagdpanther looks very beautiful, nice paintwork Simon.
best regards Yves
nice to hear from you yves and tim, yes yves i am running out of space, once this ones finished i will have a move around but the speed i'm going thats a while away, thanks for posting, regards simon.
not much to report on my build at the moment, just a few photos of progress, early stages of zimmerit application, i reworked the armortek exhaust kit parts to this stage using files and mr dremmel, the zim paste is wall tile adhesive with added pva glue, the mike stannard application tools are a must, makes the job much easier, all the best simon manning.
Per Sonnervik
Been liked: 2 times
Post by Per Sonnervik »
Hello Simon,
I must say it looks very good and you must´ve worked hard at the exhaust pipe base as this is different to Armortek´s - could you show us how you did it?
I hope you´ll bring this Tiger II finished to Open day for all of us to enjoy.
/Per
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi Simon.
Another classic build from you on the way I think, love the exhausts like Per said . . . looking forward to more.
Cheers Paul :wink:
01524 720977
nice to hear from you both, per its hard to describe without pictures but basically i cut a groove to act as the flange that bolts to the tank and worked backwards away from it, shaping with hand files and the dremmel, there is enough metal on the kit part to do this, i made the extra oval flanges from sheet alloy, what gave me the idea was freddies post and pictures of his exhaust, i printed them off and had a go, not as good as yours or accurate but a representation, if confused, i will see you at the open day, the tiger will not be with me, i am on a go slow due to house repairs etc, many thanks simon.
Steve Norris
Has liked: 8 times
Hi Simon.
Great looking exhausts. You have got me thinking about reshaping mine now as i only rounded the edges off.
