My 222
Bodo Langbehn
Been liked: 25 times
Re: My 222
Post by Bodo Langbehn »
Hi Simon,
you have built a really nice 222. I like the color.
Bodo
Re: My 222
looks convincing simon, these 222 are a good model, plenty of options, well done, regards simon manning.
Lawrence Godson
Re: My 222
Post by Lawrence Godson »
Excellent model Simon !
Could I ask you raised the gun mount to its correct position?
Larry
Lawrence Godson
Simon Peck
Has liked: 7 times
Been liked: 46 times
Re: My 222
Post by Simon Peck »
Hi Larry.
My 222 is not yet finished, but I found if you place the steel strip that the gun cradle is fixed to, and in turn should be fixed to the underside of the turret ring, on the top side of the turret floor, then the guns sit at about the correct height. You'll have to put some kind of spacer on top of the pedestal to fix the raised mechanism and allow for a smooth rotation, but I think it should be quite an easy mod when all is said and done. When I can I'll post a picture that will be better than a description. I'd like to do some more mods to the guns and gun mount, but at the moment I'm snowed under with moving and work. I hope that helps to explain things?
Simon.
chris quick
Re: My 222
Post by chris quick »
Great work Simon :!: :!: :!:
groetjes uit Holland
Has liked: 161 times
Been liked: 847 times
Re: My 222
Nice 222 Simon, Really came together nice! Great work!
Best regards, Bob
Simon Peck
Has liked: 7 times
Re: My 222
Thanks for the kind comments, I hope I can add some more to this thread soon!
