WOW Brian!
I am sorry for your vendor woes....its always disappointing to hear stuff like this.\
But, it sounds like you are building a superior furnace; and, you will get many years of service. So, I hope that offsets some of the pain......
Best Wish,
Jim
Making of the PzIII/Iv Cupola
- Been liked: 3 times
Re: Making of the PzIII/Iv Cupola
Hello Everyone again!
It has been a few weeks, I am sorry. I started in a new position and has been taking up a lot of my time.
I am mostly finished with the new foundry, the sheet metal and fire bricks are cut and fitted, I have drilled the holes for the new burner and the exhaust, added the handles. This week I expect to add the castable refractory this weekend for the lid and the bottom of the foundry. I will also be adding the legs and handles to the foundry before casting the refractory. So casting some brass should start the following weekend.
I bought a nice draft air burner and I have built myself a forced air burner, so I should have plenty of energy to fire the foundry. I will post some pictures of them in comparison this weekend too.
So, here is what I have done:
This is a view of the foundry showing it from the top with out the lid
This is a view of the foundry from the bottom with out any of bottom brick layer, The bars and ring are for support of the castable refractory
Here I am drilling out the hole for the burner. The screw clamps were only for support during construction.
This is the fire brick for the bottom of the foundry. It is cut on the table saw, than the radius is cut on the bandsaw
Here the fire brick for the bottom is test fitted in the foundry. Once again this is a view of the fondry from the bottom
I have cut the sheet metal for the lid, screwed it togather, and attached the lifting handles. It is set on the bottom of the foundry just for a test fit as I formed it.
So. There we are. I apologize for the wait. It will all get done before we get too old.
(I am looking forward to getting some parts produced too)
Have a good day!
Have a good day!
Brian
Hi Brian, have you managed to do any more to the cupola production?
This really takes boys toys to a new high!
- Has liked: 5 times
- Been liked: 710 times
I was also interested in progress. Will you do Glass/clear resin / blocks also. I have made some for the tiger and think they would be worth adding.
