tiger suspension
Dale jordan
Been liked: 523 times
Post by Dale jordan »
Thanks for the info Roland . I will check my ride hight tonight . Can you post a photo of your tiger fully loaded side on !! So I can compear my tiger to yours . If not can you E.mail me on markjordan@tsn.cc . Dale
Roland Mann
Been liked: 19 times
Post by Roland Mann »
Sorry Dale, I have no actual pictures with fully loaded as you say.
I have taken it apart for various work on the gun, the turret and the gun elevation. You may get an impression from the gallery if you watch out for
turret.
To all other Gentlemen with adjusting problems on the torsion springs
( bars ) for correct hight, I can recomend the twisting of the springs. Fit one end in the vice ( preferable the end in the fixing block ). Then twist the other end as much as needed to receive the correct angle. No problem, the material is spring steel and will perform well. It will take a caution hand to feel and find the elastic limit. Then a bit mor and it will stay in the requested angle. I have done it this way and have precisely same angles for all my axles.
Best regards Roland
Der Weg ist das Ziel.
Has liked: 1490 times
Been liked: 1697 times
I realise this is a little late but this is an enduring subject :D
Below is a shot of the belly of the Bovington Tiger, showing the positions of the swing arms in relation ot the hull floor.
Dale jordan
Thanks Adrian ... I have been waiting over a year for that photo . Yes my tiger is about 3mm higher then that shot . I looked at all the gallery photos of all the real tiger around the world but no photos undeneath . well done . Dale
