Battery Charging
Battery Charging
Is a 12 volt battery charger connected to the special plug supplied, suitable for charging direct or do I need to charge each 12volt battery separately?[/img][/quote]
- Been liked: 2 times
Electronics and electrics are not my strong point as i am a mechanical engineer, however , i am told that if you have 2 x 12volt batteries connected together to give you 24volts , then it is better to charge them as a complete unit useing a 24volt charger, They will balance themselves out , charging evenly .
Was die Hölle das war
- Been liked: 3704 times
Gentlemen
If you ask 100 engineers how you should charge a battery, you will get 100 totally different answers. Some will tell you it is important for battery life to do one way, others will tell you that it is important for performance to do it another. Our experience is that it actually makes very little difference. Modern sealed gel batteries will handle all sorts of abuse both in use and in charging. You could spend hundreds on fancy battery chargers, and they may extend the life of the battery or improve its performance. Personally I doubt it, but I am just 1 in 100 engineers! We use a brute force and ignorance 24volt truck battery "start and charge", and use it flat out to charge the batteries in about 20 minutes. We have never had a battery fail.
Wow Mark in only 20 minutes???? That's fantastic!! I was told to be very carefull with charging the batteries. And to get the best result one should charge them separately with a 12V charger! I've got two 12V 2.5 Amp/h chargers which take them a long time to fully charge both batteries! I am happy to hear that it can be done in 20 minutes!!
Matthijs
Matthijs
- Been liked: 10 times
I agree with Mark that battery charging is a bit of a black art. It is possible to charge modern batteries quite fast but the danger, especially with sealed batteries, is forgetting you've left them on charge. When fully charged they heat up, gas and can eventually explode. This happened to me with a 7.2v Nicad pack that I forgot about and left on a fast charge. I bought the Accumate three cycle intelligent charger, so it charges fast initially, then when the battery is about 80% charged it switches to a medium charge and finally when the battery is fully charged it switches to a trickle charge just keeping the battery topped up. It says that the battery can be left on the charger continuously. It is also switchable between 12v and 24v so you can charge a pair or individually as you like. I always leave the batteries as a pair.
I think that the other important thing to do is cycle the batteries. If you run the model regularly (1/2 - 1 hour permonth) then no bother but if you don't it is good practice to cycle the batteries. I do this using a 24v light bulb, but to avoid completlety flattening the batteries I use a timer working a relay to switch off the bulb after about 10 hours. Some battery chargers don't recognise a completly flat battery and won't charge it. You will find that if you don't do this battery capacity will fall and their life is reduced.
Allan Richards
Hi all
All Of the Guys In the Devon tank club use the accumate 12/24v charger and charge the powerpack as a 24v unit.My understanding is you should always charge a battery as soon as you have used it as they like to be fully charged and perform better.This goes for all types or lead acid,calcium,agm,deep cycle leasure etc.Its just that they are built differently inside and certain ones can sustain being used for a long time then charged.
Charging tank batteries in 20 mins!I think I will have to get me one of those chargers for weekend events
All the best
Marc
All the best
Marc
Vere did all zose shermans come from ?
