T34/85 25th Guards Brigade No 234a
- Has liked: 1564 times
- Been liked: 835 times
Re: T34/85 25th Guards Brigade No 234a
It's safer on the ground Phil. Are you able to drive the T34 through the house and then outside????? Nice day for a run....Mick
- Been liked: 223 times
Hi Mick
Yes I can get round the corners and through the doors ok and I use that pvc carpet
protector with the little pimples on the underside that grip the carpet,the rolls are
about 1M wide and I have a ramp to get out the kitchen door.
But The amount of rain this week end is still only just under the lawn surface,it
takes a while to drain even though I am close to the top of a hill.
The lawn was just squelching under foot and when I pulled a little weed up out of the
gravel path it come up with a lump of soggy mud on it.
Spent the Day clearing every thing out the spare bed room except the T34-85 and vacumed
arround it
I have a Big Tree at the back of the garden that has died(fed up of being eaten by the
bugs I think),so when I chop that down,which will have to be soon before it falls down,
I will save some of the logs to drive the Tanks over.
arround it
Hello Phil, yes I know what you mean, I use carpet 'pieces' to move the Comet around the house. I have made ramps into the garage. The weather has been awful, I cut the rear lawn in anticipation of a 'run' outside.....no chance. I have booked the Comet into two local shows, 17th June, Welshpool Air Show, (full size) and the Welshpool Model Show,(models only) 17/18 August. All being well.
Should be able to make a start on the Jagdpanther deck/turret/ section soon, I have ordered upgrade parts from Steve Winstone.
Looking forward to the 'rain' this afternoon ....mick
Hi Mick
Hope you have a good time at your show.
June and July is where I turn towards the sky and visit the big military air shows,
Cosford,Yeovilton,Waddington,Fairford for RIAT,Farnborough and probably Kemble in
August.
August.
- Has liked: 5 times
- Been liked: 672 times
Hi Phill, great work. Hope we can get photos of our tanks together sometime with the roofs off. Pity about the weather. I can push my trolly through the house and drive off the table on ramps into the garden. Handles the ramps with ease.
Thanks John .
Sounds like like you are very well organised with your trolly,I will have to think
about getting one.
about getting one.
Hi Phil
Your T-34 looks great!!! Are you happy with the tanks ride height? I've been seeing a number of posts commenting on how the T-34 tends to ride a little high, what do you think. Are you going to run your tracks as slack as they seem to be on the real T-34?
Any information you can provide would be greatly appreciated.
Thank you
Jim
Thank you
Jim
Great job as usual phil, the interior is outstanding It does look like its riding a little high though. Saying that I know nothing of the t34 kit, and very little of the history of tank
scratch that last post. Just looked up t34's and its an issue with these models. Superb job mate
Hi Jim and Bob
Yes my T34-85 looks a lot better on the floor than the bench,Gunter has done well
with the looks of his,but that needs to be done at the outset of the build.
Like Lee said you need the tension because the slack has to go some where,when the
motors tension up the tracks,and it usually ends up in a balloon of track at the front
or rear.
You can scale size but not weight the model tracks are very light and I wouldnt want
a full size track link dropped on me foot
That weight helps a lot when you see the tracks flopping about and they must of had
plenty of tracks shedding off even with the weight to help out.
Thanks Bob,
I made most of the bits for the Turret interior and Nick made the Amo Rounds for me.
or rear.
Thanks Bob,
- Been liked: 53 times
Hi Phil,
It's great to see your T34-85 outdoors, looking good.
It will be your Tiger next then!
Ian
from Glasgow Scotland
Ian
Thanks Ian,
Yes my Tiger is out aswell now,a great sunny day for a change,hope the
rest of the Holiday is the same,to give the lawn a bashing
- Been liked: 68 times
Hi Phil.
Just looks great all round mate you have done a great job in and out I really like your faded bit washed out green . . . well done indeed . . . now go trash that lawn today!
Cheers Paul.
Cheers Paul.
01524 720977
01524 720977
Thanks very much Paul
Yes today looks like it will be a lovely lawn trashing day.
