Workshop Bergepanther build
Forum for discussion relating to the Bergepanther
Paul Morris
Been liked: 68 times
Re: Workshop Bergepanther build
Post by Paul Morris »
Hi back again.
Stowage bin in place.
berg 4.jpg (40.19 KiB) Viewed 9431 times
One final overall shot of the build as it was a while ago.
Thanks for looking hope they look O.K. only just trying to get the hang of this.
Cheers Paul :wink:
01524 720977
Steve Norris
Has liked: 8 times
Been liked: 697 times
Post by Steve Norris »
Hi Paul.
Glad to see you sorted out the photo posting issues.
Great looking Bergpanther your doing, The flag hanging out of the rear bin is a realy nice touch. That winch assembly is a monsterous looking piece of kit.
Reagards
Paul Morris
Hi Steve.
Cheers mate and thanks for the help last night fingers crossed for better things to come.
Yes the winch is quite a lump and quite a weight as well.
Cheers Paul :wink:
01524 720977
John Fitzsimons
Has liked: 5 times
Been liked: 672 times
Post by John Fitzsimons »
Likethe flag. What's it made from?
Paul Morris
Hi fellas.
Bit more progress on the Berg.
Nearly there now after a few stops and starts.
Should have the tools etc on in the next day or so then do the Shurtzen.
Hope you like it more to follow.
Cheers Paul
01524 720977
Paul Morris
Hi fellas.
Bit more progress and a few more pictures. After a coat of paint 3 of Daves excellent jerry cans were fixed to the wooden decking of the Berg.
I was going to use a conventional stain for the woodwork but decided to go for an enamel/turps wash in two wood shades and I think it has turned out quite well, the wooden planking on the outside of the compartment was done the same way prior to camo paint.
Last picture just an overall shot of the whole thing which is fianally starting to come together . . . I think.
Cheers for now Paul :wink:
01524 720977
Paul Morris
Hi fellas.
Well light at the end of the tunnel so time for the lads to take a break :D
Now that the tools are on I managed to get the shurtzen primed in the sunshine, so ready to start putting the tracks together now.
One hell of a lot of weight in this model it will be fingers crossed when the time comes to sit her on her tracks for the first time?
01524 720977
Steve Norris
Has liked: 8 times
Paul,
Great looking build.
Been liked: 1644 times
well done paul, a handfull of a job and a complicated build, how about one from scratch just to keep you busy. regards simon.
Paul Morris
Hi Steve and Simon.
Thank you very much for your comments they are most appreciated especially coming from yourselves :D .
Got the shurtzen painted and in place,
these can now be removed and wrapped up safely for collection. So only the crane parts to build and paint, then fit the tracks and this one can be put to bed.
Thanks again for posting guy's, I was starting to feel lonely in this section :lol:
Cheers Paul :wink:
01524 720977
Steve Norris
Has liked: 8 times
Paul,
Have you got any shots through the drivers/radio ops opening ?
I noticed you have detailed this area and was wondering how much room there is when the motors are installed.
May try something similar with the Panther although less will be visable when viewed through the hatches.
Paul Morris
Hello Steve.
Sorry mate I can't now that the winch is in place you can see very little at all of the inside, its nothing like being able to lift off a turret.
I just had a quick measure for you and I get 55mm from the deck to the floor of the kit provided box that forms the driver compartment, this is fairly close as I have only covered it with plasticard chequer plate, below the kit supplied box you have only around 15 mm or so befor you hit the drive motors!so only around 70mm all together, I know it was a fiddle getting the wires and linkage for the M.G connected . . . much swearing and puffing and blowing ha ha.
As I think I said before all I have done is only semi scale just to add some interest to an otherwise plain area of the model, I suppose you could make up your own driver box to suit your own requirements but I only did this off my own bat to make the customers model more individual, hope he likes it :). I used Daves seats for what I have done and they needed the back rests to be shortened a little so they would fit in.
Hope this helps a bit, and I look forward to seeing what you come up with as I still have my own Panther to do.
All the best Steve cheers Paul :wink:
01524 720977
Steve Norris
Has liked: 8 times
Paul,
Thanks for the info. Will see what is required when i get the motors installed.
As i said before there is much less visable through the hatches, so just a small amount of detail may be sufficent.
Paul Morris
Hi fellas.
Well got the crane parts done and painted.
It works quite nicely, bit of paint on the bucket and fit the tracks now, its been a good weekend, having got more done than I expected.
Cheers for now Paul. :wink:
01524 720977
Nick Farrugia
Post by Nick Farrugia »
HI Paul
just like to say that you have done a lovely job on the bergepanther your customer should be over the moon well done.
all the best ,,,,,,,,,,,,,,,,,,,nick
