Ultimate Panther/Jagdpanther Build
michael hilton
Has liked: 1564 times
Been liked: 835 times
Re: Ultimate Panther/Jagdpanther Build
Post by michael hilton »
Hello Phil, hello Steve, thank you for your replies, I had a trial fit of the glacis plate which covered the front csk holes.....so, no fitment there, these can be filled.
I know somewhere I have seen a comment saying that the eight 6m csk holes in the hull side plates can also be filled.
It's not a big issue, I would rather do this now while I have easy access.
Thanks again lads.....Mick
michael hilton
Hello....a little help required please.
I am fitting the hub caps, on my Ultimate Panther, so that I can protect the bearings when I prime and paint the wheels.
They are screwed in , finger tight.
Do the caps screw flush with the wheel???.
Also,one or two of the caps are 'binding' and do not screw in as far as the others.
Is there a way to 'ease' the hub caps...I have tried a thin spray grease, without success???.
I do not want to screw the hub cap in too tight,in case I can not remove them.
Thanks in advance....Mick
leesellars
Been liked: 15 times
Post by leesellars »
Hello Michael
When i did my BergPanther I also found that the hub caps binded a bit. Al i did was put a bit of Grease on the threads and that went in a treat. I also made a special tool for fitting and remaoving them.
Also check that the washers to hold the wheels on doesnt foul on the inside of the Hub cap If i remember rightly i machined a bit of material out of the center to enable better clearance.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
phil fitzpatrick
Been liked: 223 times
Post by phil fitzpatrick »
Hi Mick
A couple of easy things to try to see if they close up a bit more.
An old tooth brush run round the hub threads to see if you missed any swarf.
And a bit of a wire brush of the hub cap thread then try them again.
Hope that helps a bit
michael hilton
Thank you Lee, and thank you Phil, sound advice. I will do as you both advise.
I don't want to stress the fine threads. A rub around the threads to make sure they are clean and smear of grease should do the trick.
I have attached a photograph....not very clear. The nearest photo shows the threads to be proud by 2/3ml. The wheel at the rear has the hub cap about 1ml.
I have assumed that the hub caps do not tighten down flush???
I have to be careful...I will need to remove the hub caps later.
Lee, I had thought about some sort of tool, you can't get much purchase using only your fingers.
003 [800x600].jpg (63.59 KiB) Viewed 4173 times
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi Michael.
Lee is correct I had the same thing with the caps I used a drum type sanding attachment on the dremmel you know the one with the expanding rubber centre piece, dead handy as it just fits inside the recess on the caps 30 seconds each cap and your laughing.
Coming together nicely by the way.
Cheers Paul.
01524 720977
michael hilton
Hello Paul, Lee and Phil, thank you all, for this advice....yesterday evening, I tried the light sanding/grease route...which made all the difference. The hub caps are 'sitting' down nicely. Onwards and upwards.....Mick
michael hilton
Further to the hub cap problem....I followed Pauls advice and made a simple 'key' to turn the hub caps into the hubs...brilliant idea....saved my poor distressed fingers....Mick
michael hilton
Wheels made up with studs/nuts...hub caps fitted and masking tape applied ready for spray painting.
First coat of UPOL Etch primer.
005 [800x600].jpg (92.07 KiB) Viewed 4012 times
I sprayed in the garage..although cold...then quickly transfered the wheels into the warm office/workshop/bedroom...
003 [800x600].jpg (71.06 KiB) Viewed 4012 times
michael hilton
Some more spraying....although not really the weather for it....
Brass rod fitted.... my attempt at detailing...hardly rocket science, however, it allows me to say when asked....well I did make some parts myself....said with tongue firmly in cheek
002 [800x600].jpg (94.48 KiB) Viewed 3966 times
001 [800x600].jpg (82.36 KiB) Viewed 3966 times
michael hilton
Wish this wet weather would improve...guess it's all down to the hosepipe ban...
Sprayed with RAL 6003 Olivgrun, and Tamiya TS3 Dark Yellow.
006 [800x600].jpg (126.39 KiB) Viewed 3902 times
Sprayed with RAL 8017 Schokolbran.
003 [800x600].jpg (62.74 KiB) Viewed 3902 times
John Wiggins
Has liked: 257 times
Been liked: 147 times
Post by John Wiggins »
Hi Mick
Enjoying your build. Like the production line approach, you are a very tidy builder!
I am (trying) to make various boxes/panniers for my Firefly, out of brass sheet. I've had to stop, for a while, i've made a mess of the current one. Thought I would come onto the forum for insperation! :) :)
Keep the photos coming.
michael hilton
Hello John, thanks for your post. I had wondered if you had made further progress.... with the Firefly build....
Being tight on space, and understanding wife, I am allowed to use the spare bedroom as a paint drying area. It's far to cold in the garage and I want to press on with the Panther/Jagdpanther. I had a vague idea that I could have it on display, part built, at the 'shows'. I think this is out of the question now, so, I may try some upgrades, within reason. These models are addictive.
Regards...Mick
Nick Farrugia
Post by Nick Farrugia »
HI Mick
wheels wheels and more wheels :D i bet you will be glad to see them finished nice progress mick keep us posted all the best,,,,,,,,,,,,,,nick
michael hilton
Hello Nick, thanks for your post.....every time I count the wheels, I can see a mistake.
Then I check them again...and they are all correct....driving me mad.
I have carried on with the spray painting.....in-spite of the weather. I spray in the garage then quickly move the parts into the warm dry spare bedroom. Bit of a pig...at least I can continue with the build, and see some progress. I will have to follow my own advice and take my time.
The colour is a red/brown,I have settled on this colour for the hull.The wheels will be mix of red/brown dark yellow and green. The dark yellow is a Tamiya TS3, the other colours are RAL mix
002 [800x600].jpg (77.88 KiB) Viewed 3799 times
The hull is very heavy,I use my small 'sack' truck, so far I have only hit the dinning room furniture once
001 [800x600].jpg (85 KiB) Viewed 3799 times
