Panzer IV F1 (No. 19)
Günter Gäbelein
Has liked: 41 times
Been liked: 195 times
Re: Panzer IV F1 (No. 19)
Post by Günter Gäbelein »
Hello,
in the last days I could finish the sprocket and the first cap for the wheels. The cap isn't in the final position. I attached the storage box to the turret and milled the gunners vision ports. At least I modified the hinges at the front.
the sprocket
the wheels cap
storage box without cover
modified hinges
wholes closed at the cupola
Günter
Nick Farrugia
Post by Nick Farrugia »
Hello Gunter
you are doing very impresive work , i like the new cap for the wheels very nice i also liked the new driver and radio operators haches they look great ,keep the pics coming always interesting.
regards to you ,,,,,,,,,,nick
Günter Gäbelein
Has liked: 41 times
Hello,
in the last days I could do much progress with my Panzer IV. I finished much things with the gun (outside turret) and the turret. I soldered a new cover for the stowage box and made new hinges for the cover.
The backside of the hull is nearly finished.
gun with antenna bumper
pins added
cupola nearly finished
hull back detailed
the exhaust ist still missing. I will build a new one, because the exhaust from the kit is to small
welds are still missing
new details for the drivers and operators hatches
Next will be some welds and some paint for the hull.
Günter
greetings gunter, i am not building the panzer 1v myself but i like the detail your adding, keep the posts coming, regards simon manning.
Günter Gäbelein
Has liked: 41 times
Hello,
yesterday I forgot to make pictures from the hatches at the hull sides and at the back. I have milled them by using a 3D-drawing. The hatches are milled in one piece and can not be opened. If there is any interest in the hatches, let me know, I could produce a prototype for casting.
Today I soldered the brackets for the exhaust. I will renew the exhaust, because it is to small. i hope that I will get the ordered brass tube for makeing the new exhaust.
Simon, I try to do my best, but every day when I study pictures of the original tank I find new details :?
Günter
hi gunter, thats the interest of the kits you can go as far as you want with the detail, regards simon.
John Fitzsimons
Has liked: 6 times
Been liked: 824 times
Post by John Fitzsimons »
The profiles of those hatches are perfect. I am willing to have a go at casting a working set in white metal if you are interested. The panzer IV has so many little details. It will keep you busy for a long time.
Mike Kasputis
Been liked: 54 times
Post by Mike Kasputis »
Gunter, your Pz IV is looking great. Love the F1 turret.
Since you are adding all that detail are you going to put the correct bolt pattern on the transmission cover.
Here is what I did to mine.
Günter Gäbelein
Has liked: 41 times
Mike,
yes I will change the pattern also. At the front of the hull I have still many things to do. Which version did you built?
Günter
Günter Gäbelein
Has liked: 41 times
John,
if you like a working hatch, I could mill the parts seperately and with or without the two bolts as a prototype.
the prototype will be in plastic.
Günter
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Impressing work Günter, well done!
Follow your build with interest, thanks for posting.
One tiny observation :oops: ...
Please note that the fuel filler ports on the Panzer IV were only on the LHS and not on both sides.
Keep up the good work
It´s all in the details!
Günter Gäbelein
Has liked: 41 times
Kent,
thanks for the information! I found it out today too, when I studied pictures and drawings (H. L. Doyle) :oops: . The hatches on the right side are already removed. :)
Günter
Günter Gäbelein
Has liked: 41 times
John,
the filler port hatches I could prototype for you would be like this
Günter
Günter Gäbelein
Has liked: 41 times
Hello,
I have finished the smoke grenade box, added some welds, reworked the small exhaust, added the pistol ports and additional parts to the gun. Thats it for today.
reworked small exhaust
first welds at the back
added welds to the hinges and the hatches
pistol port at the rear turret hatch
added additional parts at the gun
Günter
phil fitzpatrick
Been liked: 223 times
Post by phil fitzpatrick »
Very nice looking Panzer1V build Gunter :)
I like all your extra details,just spotted your internal
details for your Gun,very nice
