Hi fellows,
During a short running last Sunday, my KT was suddenly stopped. To lift it on trolley and push it back to garage was a nightmare!!!
After checking, it was found the 30A fuse in the Power Supply Module was burnt-out.
Has it happened to anybody before? This is my first time. I wonder whether will it happen again? From now on I will remember "Never run KT without having a spare fuse set on hand".
Your valuable suggestion on how to prevent it from happening again will be much appreciated!
Thanks in advance!
Lerh Chang
30A fuse in Power Supply Module
- Chang
- Has liked: 16068 times
- Been liked: 454 times
- Been liked: 68 times
Re: 30A fuse in Power Supply Module
Hello there.
This has happened to me once while moving a tank out of the workshop, it was a very tight squeeze due to other tanks on the floor and the reason it happened was I got the front of one track jammed on the leg of my bench and the fuse popped, I do believe its a safety thing to prevent any more costly damage? it has never happened since.
But the carrying of a few spare fuses is a good idea, as you found out.
Cheers Paul
Cheers Paul
01524 720977
01524 720977
- Been liked: 3501 times
Hi Chang
What Paul says is basically correct. One thing to note is that the fuse should be 40amps, not 30 amps. This is important if you have 4QD speed controllers. If you have the new Armortek speed control module, a 40amp fuse should still be fitted, but it is only a second line of defense. The module has built in real time current limiting to protect against fuse failure in normal driving conditions.
- Chang
Thanks Paul and Mark for the advices.
Back on late September 2011, after changing of 18-teeth sprockets and Oalf's late-type single tracks, the KT had made more heavy duty runnings without broken down. The last Sunday running was the 1st time after adding of one extra track link (from 97 to 98 each track). I wonder did the track jammed while doing backward/steering?
Made in steel alloy, it was nearly as twice heavy as the original track. Could that be part of the reason?
Anyway, I will prepare more of 40A fuses just in case. The 30A fuse was connected as Armortek's stock part.
Regards,
Lerh Chang
Regards,
Lerh Chang
- Been liked: 603 times
Hello Chang,
Is it possible to show a picture of the 18 teeth sprocket an de single track links?
Thank you.
best regards Yves
Thank you.
best regards Yves
- Chang
Hi Yves,
Here are several photos taken a few months ago. Sprocket ring was un-paint yet, and 97-link-track (13.6kg/track) was too clean:
Regards,
Lerh Chang
Regards,
Lerh Chang
