Panzer IV F1 (No. 19)
- Günter Gäbelein
- Has liked: 41 times
- Been liked: 104 times
Hello to all,
my kit (No. 19) arrived on November 24th. It is my first Armortek kit and I am very impressed! The plan is to build a F1 version with the short barrel.
Günter
Günter
Re: Panzer IV F1 (No. 19)
Hi Gunter
If this is your first it wont be your last, Happy building.
regards nick
regards nick
- Günter Gäbelein
Hello to all,
my constuction of the Panzer IV is similar to that of Nick, so I haven't posted pictures until now. In parallel to the build up of the hull I have constructed some parts to recreate the cannon inside the turret. First I ordered the interior detail part from Tim, but then I found some pictures and drawings of the gun interior of the L24 gun. The interior of the L24 gun is different to the L48 gun and I decided to make it by myself. The plan is, to make the recoil also for the interior of the gun. i have two small cylinders which I will combine with the same valve like Stephen used for his Panzer III.
Günter
Günter
- Has liked: 1211 times
- Been liked: 1386 times
Excellent L24 gun Günter
Were those parts made by CNC machining ?
- Günter Gäbelein
Hi Adrian,
yes I have a small portal milling machine. I used 10mm thick polystyrene plates, milled discs and glued them together.
Günter
Günter
Hi Gunter
If this is a sign of whats to come, its going to be good keep posting
regards nick
regards nick
- Been liked: 386 times
Nice work. Hope you get the recoil working.
- Has liked: 104 times
- Been liked: 701 times
Gunter,
Welcome to the forum. Very nice work on the L24 gun! Keep us posted of your progress. I like the look of the machined turret!
Kind regards,
Kind regards,
- Günter Gäbelein
Hello,
it is going forward. I have changed the drivers sight and the hatches. I have milled new periscope inserts for the cupola and also a new commanders hatch. The gun has got also a few new parts. Next will be the new caps for the wheels. In January I will get a new idler wheel, I have already sent the construction data to the caster.
new drivers sight
new hatches
turret doors attached
cover attached
new periscopes and new hatch
new parts for the gun
armoured vent
signal hatch
new idler wheel (CAD-data)
new caps for the wheels (CAD-data)
new drivers sight
new hatches
cover attached
armoured vent
signal hatch
Günter
Günter
Great work. I like what you have done with the cupola view ports. I was wondering how these worked as I want to make the glass blocks for this.
Hi Gunter
your tank is looking very good i realy like all the extra parts you are adding this is going to be one of the great builds you see on this forum, keep the pics comming .
regards to you ,,,,,,,,,,,,,,,nick
Hi Gunter,
Superb work on your Panzer 4. The L24 gun is amazing. I am interested to see what the new idlers look like. Are you having them cast from aluminum or zinc-alum alloy? Excellent work and interesting modifications. Kind regards,
- Günter Gäbelein
Bob,
I will get the idler wheel casted from aluminium (this is the plan). The caster will make the idler in January.
Günter
Günter
- Günter Gäbelein
Hello,
a few pictures from my work yesterday.
I wish you and your families a Merry Christmas and a Happy New Year
Günter
Günter
