How to:
- Mick Regan
- Has liked: 34 times
- Been liked: 6 times
How to:
Fit the Benedini Rotary Encoder on a Futaba 7C transmitter.
After recent discussions regarding the rotary encoder, plus the fact the original post is 5 years old, I have added a few extras.
This is a fairly simple modification to the Futaba transmitter which involves a small amount of soldering.
As with all modern electronics, some components are prone to damage due to static discharge. Keep handling of the transmitter boards to a minimum.
Finally, but most important. If your transmitter is new, THIS MOD WILL INVALIDATE YOUR WARRANTY
*For the Futaba 7C transmitter, the 2 soldered bridges indicated above, remain in place*
*The channel on your receiver that controls your sounds will be channel 6*
First you have to get the back off the transmitter by:
1/ Remove the battery cover.
2/ Unplug the battery.
3/ Unscrew the 4 screws.
Next, get access to the channel 6 controls:
4/ Remove the knob from CH6 and unscrew switch D.
5/ Remove the screw securing the circuit board. Unscrew switches G and H.
6 / Carefully release the circuit board, and then unsolder the rotary switch and the toggle switch.
Installing the rotary encoder:
7/ Solder the leads of the rotary encoder to the circuit board at the original rotary switch position.
THE RED LEAD MUST GO IN THE CENTRE POSITION.
The brown and orange lead can go in either position.
8/ Install the rotary encoder and toggle switch in the CH6/D position.
Refit switches G and H. Refit the original circuit board in a position where it will not come into contact with the joystick or trap any wires.
9/ Fit the knob to the rotary switch and the nut to the toggle switch.
Refit the back of the transmitter, and refit the battery and cover.
You are now ready to test the encoder.
10/ Connect a servo to channel 6 on the receiver.
Operate the toggle switch, then rotate the encoder knob through each position. The servo should go through its range in 12 smooth steps.
You are now ready to reconfigure your sound unit.
Hope this helps
Mick
P.S. If anyone is interested in any other systems or radios, I'll consider adding more "How to" posts.
Hope this helps
Mick
- Has liked: 20 times
- Been liked: 737 times
- Been liked: 1 time
Hi Mick
That's a great Mod, very nice pictures.
I consider for a long time whether I with my Futaba ff-7 Fasst should also make, however, has not dared me. The rebuilding of the Rastung of the right tax bat was already very fiddly. Now where I this here see I will also try it.
best regards
Holger
best regards
Holger
Last edited by Holger Hoffmann on Thu Sep 24, 2009 5:52 am, edited 1 time in total.
Holger Hoffmann
- Mick Regan
Hi Jeff
I'm not familiar with the T8UPS transmitter, though I have just downloaded the manual and will have a look to see if it is possible. Can you tell me where the controls for channels 5 to 8 are located on the transmitter
Hi Holger
The mod on the 7C is probably the easiest on all. Most of the work is on an easily accessible board, so there is very little danger of damaging the transmitter.
Mick
Hi Holger
Mick
- Has liked: 1421 times
- Been liked: 1603 times
- Mick Regan
Hi Adrian
I have fitted an encoder to a 6EX, but you have to use 1 of 4 stick operated channels. It requires a lot more disassembly. I use it to control a Benedini TBS mini sound board in a 1/6th Kubelwagen conversion.
I pesonally have changed my control method to a 12 switch pack mounted on the back of the transmitter. The circuit was supplied by Thomas and the layout was sorted by Stuart and Howard at the UKTC. Heres a pic
You can assign any button to each sound. It is the setup I have always wanted, but there is a fair bit of circuit building involved.
Mick
Mick
- Has liked: 189 times
- Been liked: 716 times
fitting encoder
Hi Mick
Great step by step guide, i did this mod in about an hour on a Futaba 7C transmitter start to finish, all works fine.
Thanks David
Thanks David
- Mick Regan
Re: How to:
BUMP
- Has liked: 5 times
- Been liked: 682 times
Re: How to:
Had this saved already. I hope to have a go soon.
- Has liked: 258 times
- Been liked: 187 times
Re: How to:
Hi
Thanks for going Bump in the middle of the night! I have now used these instructions on two transmitters sucessfully, all straight forward.
- Been liked: 22 times
Re: How to:
Hi Mick,
Thank you for taking the time to post these great tutorials. Great stuf.
- Mick Regan
Re: How to:
BUMP New addition added
Re: How to:
I have now used these instructions successfully four times, really invaluable. They make it fairly straight forward to do the job.
Many thanks, Steve
Many thanks, Steve
- Has liked: 10 times
- Been liked: 223 times
Re: How to:
Mick,
This all seems contradictory as in your and the manual's instructions the bridges should be closed for a 7C (which I agree with) yet Chris Glover was told by Thomas to remove them. Unless I am reading things wrong. I use my own design anyway. Confusing or what !!!
Dennis.
Dennis.
Last edited by Dennis Jones on Wed Dec 24, 2014 12:13 pm, edited 2 times in total.
Re: How to:
Very confusing......It's Chris Glover!Dennis Jones wrote:This all seems contradictory as in your and the manual's instructions the bridges should be closed for a 7C (which I agree with) yet Mick Glover was told by Thomas to remove them. Confusing or what !!!
Dennis.
