Jagdpanther build at last
Been liked: 1641 times
well i i'm over here now starting on the jagdpanther, i must of had this tank 2 years at least, i have collected as many parts as possible, i have three books to draw reference from but no idea to what camo scheme or design but it will have to be a late war theme,any good color suggestions welcome, regards simon.
Tim Bowman
Been liked: 177 times
Re: Jagdpanther build at last
Post by Tim Bowman »
:D Like everyone else Simon, will be watching with much interest. Good to see another Jagdpanther.
here's some photos of progress, i purchased this can of cellelouse paint 2 litres from the auto paint people i use, a cancelled order from another customer and a good price, not a bad colour for the tanks interior, the etch primer from u-pol is a good buy aswell it covers and is easy to handle and a third of the price of acid 8, if you buy packs of 12 ther'e even cheaper,after all you only want something to stick to the bare metal, build the texture up with normal grey primer afterwards and a much cheaper way around, all for now regards simon.
Tim Bowman
Hi Simon
HA....my 88" 2A is Limestone. :D Only it's not all shinny and new looking like your Jagdpanther.
best regards
not much to report so far, inspection covers for the bottom of the hull in there basic turned state, more work to finish them of and fit, made a start on the muzzle brake, and derek attree sent me some grill fillers to make the inner contours, i did the last ones on my panther with chemical metal, a lot of work!, thanks for posting tim, regards simon.
the gloomy dark evenings are here, so the best place to be is in the workshop, the muzzle brake is nearly completed, once again i've hollowed out the interior with the dremmel and made some lock rings on the lathe, the barrel rifeling i did with a hacksaw, onwards to the next part, regards simon.
leesellars
Been liked: 15 times
Post by leesellars »
Hello Simon
Love those Muzzel Brakes 8)
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Has liked: 126 times
Been liked: 758 times
Simon,
Your muzzle break is outstanding. Hard to believe it started out as the kit MB- wow! How many hours with "Mr Dremmel" does it take to grind out?
thanks robert and lee for the input, the muzzle dos'nt take that long, the tool in the dremmel is about as good as you can get for size and the right dimension and when new they are very sharp, i made a little sanding disc that i can fit inside the muzzle with sticky interchangeable pads,40 grit, 80 grit and so on. just another way of improving the kit part if you wish with not a lot of expense. thanks simon.
William Gardeniers
Has liked: 45 times
Been liked: 280 times
Post by William Gardeniers »
Lovely Muzzle brake Simon
always looking for your update's on your Jagdpanther.
Best Regards William
With Regards William
the jagdpanther build slowly continues, reworked the kit parts as close as i could to photos to hand, all the underneath hull inspection hatches fitted plus drain plugs, not shown in these photos, i aim to make and alter as much as possible before assembly. thanks for having a look. regards simon.
martin pitcairn
Has liked: 781 times
Been liked: 8 times
Post by martin pitcairn »
Nice to see this cat is coming up to to your usual ( but very high) standard, i will watch this one closely !
Thanks for posting Martin, just a selection of pictures of the build. Thanks to Steve Norris for the idea of access through the motor mount. Which I drilled and the access covers for the torsion bars, tried out some colour on the fan cover.
Thanks for looking, Simon
leesellars
Hello Simon
Fantastic. Looks like you have been busy
Lee
John Fitzsimons
Has liked: 5 times
Been liked: 669 times
Post by John Fitzsimons »
Brilliant work Simon. That muzzle brake is the business.
