![Image](http://i1008.photobucket.com/albums/af210/strat1920/turretsightblock.jpg)
This is only the 4th try and it's still not right. Steel and brass. Thankfully I will only need to use smaller bolts and dremel the holes a little more apart. The washers need to be thicker (the same as the sprocket washers). I'll need a bit tighter bend in the sight wire too.
Brown
