PIII Schwingarm
- Been liked: 3 times
David,
I think I made a mistake here. The arm Gill had sent me was a
P III arm. As far as I know, they are not working on a P II Actually, as iunderstand the P II arm is very different, kind of like the P IV suspension, but backwards, reversed. I intend to make that too,
How is your P IV coming a long? I liked the camo so far as it was done. I had seen paterns like that on P IIIs. If I do an N PIII I will copy it maybe.
Take care,
Brian
Take care,
Brian
Brian
- Has liked: 1477 times
- Been liked: 1675 times
Adrian Harris wrote:Brian, I wouldn't worry about the model of the arm
I think there's a viral wave starting on the forum to get the next model to be a Panzer II![]()
A wave to which I would certainly add my support![]()
Any derivatives of the PzII chassis? If so we might get a universal PzII hull.
If not, we will just have to cope.
Hi Brian,Brian Leach wrote:David,
Take care,
Brian
Sorry for the confusion.
I took advantage of your typo (You typed PII instead of PIII at one point) to make another (viral) plug for a PzII.
Also, you have me confused with someone else. I only have a PzIII and German halftrack..
Cheers...
- Been liked: 2 times
Hi Brian,
The Swing Arms are looking very good
It's interesting to see that there are a lot of different skills in the community and how various people tackle the same problem. Casting the Swing Arms is an impressive solution. Your testing regime still makes me smile
Regards,
Sarah
Regards,
Sarah
Folks,
Yesterday, Brian sent me a "sample" of his Panzer III/Stug III Aluminum Swingarms.
I can only say that I have been in awe of it from its arrival. I got a "in-the-raw" sample arm; but, with a bastard file, some emery cloth, and a stainless wire brush - I had it dress-out in less than 20 minutes! The casting was THAT GOOD!
And, the only time I have put it down since was to sleep last night.
Now, I do believe that Brian's planning to offer them up for thos interested in a finished form - dressed casting , drilled, and threaded. So, they can be purchased for simple painting and install for those who are interested.
I know, we have seen some nicely modified swingarms; but guys, all I can say is.....IT AIN"T THE SAME!
I have already sent Brian an email "begging" for more!
I can't say more, you just have to "experience" them!
Thanks,
Jim
Jim
- Has liked: 65 times
- Been liked: 5 times
Paul,
I have cast about 36-40 swingarms. Now I need to machine them.
I bought a three axis DRO for the mill. Prepretory to installing the DRO I have been doing some maintanence on the mill.
Somewhere on the front of the machine should be the warning:
DO NOT TRY THIS AT HOME
(not that I would have listened
Actuall it is not too bad. Kinda need to make a new part, but I need the mill to do that. It is not critical so, I'll put it back togather today and start teh DRO install.
It never ends. I am glad I like this kind of work.
This week the mill, than I start maching (with confidance!)
Cheers!
Cheers!
Brian
- Been liked: 177 times
- Has liked: 161 times
- Been liked: 830 times
