Futaba Help Please
richie wignall
Futaba Help Please
Post by richie wignall »
Just purchased a Futaba T9CHP super 9, having a few problems with, when i power up on the tank the turrent rotation and elevation motors run for a couple of seconds. This is every time I power up. This is causing the turrent to rotate about 6 inches and the elevation up 1 inch. The rotation is on the left stick, (left to right) the elevation is on a C Switch (a 3 way switch).
Has anyone got any ideas how to stop this?
Another thing I have noticed is when I have got my Benedini sound system running, whilst it is on idle if I put throttle on with both sticks the sound starts (engine revs) but when I go back to centre again, the revs stop dead, just left with idle. i don't this this was like this with my old system, as i was sure the engine faded down gradually instead of stopping dead, which is more realistic.
One last thing, channel 3 and channel 6 both work the same. When i operate channel 3, if I have a servo attached to channel 6 this will work as well, when i operate channel 3. I think this is mixed, but can't seem to get it unmixed, been through the instructions several times (but not very good when it specifies helicopter, gliders and planes).
I have -
Channel 1 for sound
Channel 2 track
Channel 3 track
Channel 4 turrent turn
Channel 5 gun recoil/blank firer
Channel 6 spare (but will be figures)
Channel 7 gun elevation
Channel 8 MG movement
Channel 9 lights
Any help on this would be appreciated
Mick Regan
Has liked: 34 times
Been liked: 6 times
Post by Mick Regan »
Hi Rtchie
I think your problem is that you are in a preset helicopter mode. Radios designed for helicopters have lots of different offsets pre-programmed to make flying easier. Your problem with the 2 servos working together is probably the throttle and collective servos working together.
Look at your manual and see if you have a factory reset or a basic setting for a glider. That will give you your most basic setup.
Best of luck
Mick
richie wignall
Futaba super 9 help please
Hi Mick
Nice to hear from you, hope you are keeping ok and not working too hard. Thanks for that. i am in basic helicopter mode, looked at the instructions several times, I am also learning to fly a helicopter at the moment but is a really complicated thing to get in to, I think, but fun when its in the air. i will have a look again in the instructions and find the glider mode.
Thanks again for your help.
Richie
richie wignall
hi mick and allan :P
thanks for the help, now sorted, :P vell happy with the super 9 set , £229 from hong kong and free shipping :P :P same thing in preston £ 520 :shock: :shock: . i love a bargain :lol: :wink:
thanks again.
richie :wink:
Mick Regan
Has liked: 34 times
Been liked: 6 times
Hi Richie
Glad to hear everything is okay now. What was the problem :?:
All you have to do now is keep the missus away from your tank. :lol: Just had a new workshop delivered, and I've got the only key :wink:
Mick
