Hi Mick
I forgot to add to my reply above,that I will be changing my track pins to
be facing with the big head on the inside.
The reason is if you look at photo 122 and 123 in your new book you will
see that the fastener looks to be on the outside of the track,although it looks
as though it is a "C" clip in a groove,you can see the gap on a few of them.
Picture 126 and 127 also show the big head to be on the inside of the track.
Looking at the Shepton Photo's of the proto type that Mark did you can see
the big heads on the inside.
Its personal choice though at the end of the day because you will have the
split pins showing on the outside,see what you think when you study the
pictures in the book.
But when I take my tracks off I will alter mine then,thought I would let
you know so you dont curse me if I confuse you
