King Tiger Build
- Been liked: 1633 times
This is what I have been working on, the muzzle brake. There is a lot more detail in this part than I first realised. I used the original armortek part and hollowed it out using mr dremel as kent would say. Time consuming and tricky. The O-rings were made from guess-work, with no real clear photos of these parts. This has been the hardest alteration so far.
Simon Manning
Simon Manning
- Been liked: 1 time
- Been liked: 177 times
- Has liked: 20 times
- Been liked: 737 times
- Has liked: 123 times
- Been liked: 754 times
- Been liked: 31 times
Simon, I can only echo what the other guys have said, very impressive handling of the Dremel, the MB looks like a shining jewel.
Maybe too late but here´s a photo that might be useful;
As you can see, inside the first chamber, there are two rings with six cut outs (for some sort of a spanner) on this "lighter" muzzle brake.
Also at the back (on the extreme left in the photo), on the locking ring, the cut outs (four of them, also for some sort of a spanner) they only go a certain distance not the whole width of the locking ring.
At the front, two cut outs (diagonally) to help screw the MB onto the barrel.
There are also a French drawing that show some of these details but be aware as it contains some errors, se here;
http://www.panzerbasics.com/index_files ... awings.htm
Cheers Per
Cheers Per
- Has liked: 1364 times
- Been liked: 1564 times
- Been liked: 68 times
Hi Simon.
Very nice mate...and you tried to tell me doing anything in metal was a chore for you Mmmmmmm lol
Well done Paul
Well done Paul
01524 720977
01524 720977
