Kent`s Panther build
- Been liked: 3 times
- Been liked: 10 times
Hi all!
And thanks for the kind comments.
Per//
David Byrden mention it on his Tiger 1 info site
http://tiger1.info/EN/EngineRearSupport.html
Strange that it is not mention in any Panther books but is quite evident in photos and drawings.
The 25mm have I also got confirmed from Saumur.
Please note how the cardan shaft comes out from the fire wall in an angle.
Not even in "The research squad" Panther project regarding the restoration of the Wheatcroft Panther is it mentioned.
Maybe in the #2 book as it will be about the engine.
One learn something new every day and that is nice
Per//
- Has liked: 155 times
- Been liked: 822 times
- Been liked: 177 times
- Been liked: 2 times
Hi Kent,
Thanks for the info. I don´t know where David got his info. (tried to look at his Maybach drawing but it was gone) but on my original T2 drawings the engine is off set by 20 mm, not 25 mm.
Not much of a difference but I would think it was the same on the Panther, using more or less the same type of engine. I haven´t found good Panther drawings, perhaps Saumur could help us with that.
Per
Per
Hi all!
Owe you the final result of the rear engine hatch with all its towing details.
Made the tow bar from a 10mm diameter aluminium rod.
The handle I got from a very well used bbq grate
that had the needed 3,5mm diameter.
Wanted to go all metal but a plastic rod would have been easier.
The handle shall have a 20 degree outward bend and I attached it to the rod with a tiny screw.
Good ww2 photos of these items are hard to find.
But in every one of them the handle look as I made it even if preserved Panthers has a huge variation in their look.
Here is a (bad) photo but the chain length and the handle design can be seen.
Seen is also that at the ends of the chain a ring was attached.
Found a very in scale brass chain in one of my old (and never finished) Billing Boats kit
Here are some photos of one of Saumur’s restored Panthers.
Please note that no zimmerit was applied to the engine hatch and that the nuts holding it was not castle nuts – bad post war restoration!
Please note that the pin holding the tow bar in place is not a pin but a blade with a loop.
Made it a whole lot more difficult making the hole for it…
Well here is the final result:
The all metal use makes it quite easy to weather it slightly.
Just some gentle rubbing with a steel brush (a small and soft one!).
As always, thanks for looking!
- Has liked: 8 times
- Been liked: 701 times
- Been liked: 1756 times
- Been liked: 11 times
- Been liked: 472 times
- Been liked: 68 times
Hi Kent.
Very neatly done, shame about the robot
Cheers Paul
Cheers Paul
01524 720977
01524 720977
