My Panzer III is on it's way
- Been liked: 9 times
hi all
i wont be adding the bosch lights as they are not on the ausf l i have only seen them on the ausf m
the ausf l had two small night lights on the running board and two larger ones something like the ones on the femo 7 on the front armour plate
notable changes on the second batch are the bump stops they have been rotated to the right angle
the mantlet armour has been reshaped like the original
im not sure about other changes as i havent checked yet
regards
colin
regards
colin
2006 222 SOLD
2009 pzr111 046 SOLD
Making good progress on the first phase build. Marked down a few things so far that I am going to need to change (no surprises).
A good number of the hull side bolts that attach the brackets are going to need the countersunk holes made deeper to allow them to be filled later on and I will also need to remake the lower deck to make the transmission hatches and doors the right size (not sure why Mark has not corrected this).
I plan on completely re-making the deck and doors using my CNC mill using 1/8" steel.
I will probably buy enough steel plate to make two sets just in case I screw the first up. If I don't I may have a spare set.
Remember to check my build log as it changes daily.
Having lots of fun!
Having lots of fun!
- Been liked: 429 times
Been busy of late installing and commissioning my new CNC mill as well as building an enclosure for it and a pneumatic power draw bar.
Did my first test cut on it this week and cut the new lower deck with the correct size transmission access opening this week.
Now I need to make the two new doors.
- Has liked: 1371 times
- Been liked: 1567 times
- Has liked: 10 times
- Been liked: 222 times
lower deck with new transmission hatches and doors
hi david
very nice work on the above
i hope you mind but if possable could you pm me the line drawings or measurements i would like to tackle this at some stage
regards
colin
regards
colin
2006 222 SOLD
Hi Colin,
you can download the drawing here (PDF)
http://www.scalereplica.com/images/stor ... atches.pdf
drawing
thanks david your a star
regards
colin
regards
colin
2006 222 SOLD
- Been liked: 177 times
