Cone bolts
David Da Costa
Cone bolts
Post by David Da Costa »
I think I am probably going to end up making my own cone head bolts on my CNC lathe, so does anyone have the dimension of the cone (diameter, cone angle etc) Are they all the same size?
Also can anyone tell me why cone headed bolts were used on the German tanks?
Thanks again
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Because they are stranded here from the planet Remulak :)
Brian
Sorry guys, I couldn't help myself.
It'll never happen again (another lie).
B
David Da Costa
:D
colin fairweather
Been liked: 9 times
Post by colin fairweather »
hi david
the coneheads are that shape to deflect small and large calliber rounds if a round hit a flat head bolt it could push it through the hull i dont think the crew would be too happy :cry: also if bolt heads were blown off the tank would fall apart :cry: if you look at drawings they are all at strategic points
taking angles off drawings it looks like they are roughly at 40 degrees ?
their are two types 5 small on the hull back plate and 2 under the turret pistol ports in scale these are about 4mm - 4.5mm wide ?
the rest are large about 5mm - 5.5mm ?
lads please correct me if i'm wronge
regards
colin :)
2006 222 SOLD
2009 pzr111 046 SOLD
David Da Costa
Thanks for the info Colin.
Has liked: 1024 times
Been liked: 2094 times
I've found some old notes I took from measuring the Bovington Pz III. The smaller cone head bolts were 33.27mm in diameter and 19.00mm in height. The latter measurement is the distance from the top of the cone to the plate surface.
Hope this helps.
David Da Costa
Thanks Stephen.
