Pz III New Build
Derek Attree
Has liked: 218 times
Been liked: 180 times
Post by Derek Attree »
Hi Stephen
That look stunning.
Thanks for posting the pictures
Has liked: 1024 times
Been liked: 2093 times
Driver's Vision Port - Part 2
Second part of the driver's vision port:
Still some fitting work to line up the hinge points and achieve the right movement and then fitting to the hull front plate but here's an idea of how it will look:
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Outstanding work Stephen 8) 8) as usual.
Looks like the real thing!
Tim - thanks as ever. That's the first time I've seen a photo which shows the location of the hinge pin. Although it's shown on an original drawing I've got, I haven't seen confirmation in the flesh before and you can't see it on the Bovington vehicle.
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
Hi Stephen, fabulous work on the drivers vision block, you keep setting the bar higher, and are inspirational to all of us following
keep up the good work
regards
Jeff
Has liked: 126 times
Been liked: 755 times
Stephen,
Excellent machine work. I'm amazed how you translated that maze of lines and numbers (on drawing) into a beautiful functional piece. Fine job. Those details will really make a difference on the finished model.
The almost finished article. Just the glass to add when the acrylic arrives.
Also machined the two holes for the driver's reversionary periscope and some detail on the hatches.
Dale jordan
Been liked: 429 times
Post by Dale jordan »
Hi Stephen ... Fantastic work . You sure are getting your moneys worth out of your kit... My Panzer tracts 3-3 turned up yesterday . This is a must have to go with our kits ... great scale drawing ..Dale
Kugelblende 50
The hull machine gun ball mount (Kugelblende 50) was much deeper than the kit part and the ball sat further back within the mount. The aperture was off-centre and of a rectangular shape.
So:
I've inserted a 5.1mm thick disk to give the mount the additional depth:
I've applied the cast surface to the ball itself using a wire polishing brush which seems to pit the surface very subtly and smoothed the surface of the mount ready for applying the cast surface. I've alsp cut the groove around the mount which was used to secure the fabric covering sleeve for the MG:
The inside of the mount requires filling with Milliput to provide the internal depth - shaping next week. Last job was to add an acrylic lens to the driver's vision port.
Kugelblende 50 and MG34T
The finished hull MG ball mount (Kugelblende 50):
To complete the picture, a new MG 34T barrel:
Excellent work Stephen. The ball mount looks so much better. Did you make the MG barrel? It looks awesome. Keep the details coming!
Hi Bob - yes the MG is turned from 10mm ally bar stock. It's the first piece of work I've had to try out a rotary table on the mill - trouble is now I can see a stack of things to use it for. The next project will probably have to be the brake vent housings.
Then back to the roadwheels. I've now got the correct profile having chanced upon a technical report from 1943 in the Tank Museum Library. A captured roadwheel was sectioned to analyse the metal and the report had a picture of the cut through profile.
Lawrence Godson
Post by Lawrence Godson »
Hello Stephen,
Continuing to marvel at your work. Has anything occurred relative to the possibility of producing the front hinges?
Lawrence Godson
Brake Vents
Next up the brake vents on the front hull. Started machining but needed some head scratching to find a way to hold the work:
I was waiting for the work to disappear across the workshop but it worked in the end.
Two out of three finished pieces, just the top vent to come:
Graham Ord
Been liked: 15 times
HOLDING
Post by Graham Ord »
Hi Stephen
Its nice to see you using some pretty unconventional holding methods on your mill. Some of the set ups I also employed were strange to say the least, but they work and thats the enjoyment that one gets!!!
Graham
