I have been asked to put some of my KT build photos up, but that’s been done already, so here are some of my modification/alterations. Hope you like, and criticism is welcome as long as it’s constructive!!
if you want to see more, there are lot more photos on my web page.
It's a shame to paint it paul, looks soooo good. I like the mods you've done , top quality work as usual, the question is To Zim or not to Zim, personaly i would not,
Hi Paul.
Second all of the above mate, i like the mudguard comparison shot, see you have already done the mod on the hatch we spoke about the other night looks good too now what am i going to do with this turned woodscrew ha ha.
See you Sunday.
P.S. I know what Clive means but .....i would go for the Zimm
Really Nice work Paul .. I'm slow with my KT compeared to you , I'm now working on the suspension .. Are You going to do the welds and fill bolt holes next ??? Then prime ? or are you going to test run her ..Dale
She has already been test run and she preformed really well, although as yet she has no sound.
Just got some detail left to do on the back, then strip down Zim and prime, but I intend to give you weld solution a try as it looks easier than Milliput. I still haven’t decided which camo scheme to go with yet, although it will be an eastern front camo.
Hi Paul and Dale.
I tried Dale's method for the weld on the Tiger 1 re build i am doing...i stuck with the Milliput i am used to using but the tape worked well when i removed the tape tiny little tears appeared at the sides of the weld and these i simply pressed to either side as i think the welds needed to look a little less perfect but this is only my opinion from looking at the real thing at Bovington, but thanks for the tip Dale i will use this method from nw on.
Cheers Paul
Hi Paul,
Sorry to ask you a bit late of question.
Have you met any difficulty while installing the small tow cable? It's about 220cm in length, yet I've heard that it is still 10cm in short.
It looks so good on your KT though.......
