Hi,
Does anyone have any additional info or photo's on the Panzer III MG Mount for the commanders cupola
I would like to add this to my Ausf M Panzer III.
Thanks Antony
Panzer III MG Mount
- Location: Back to Wirral home of the brave or not so brave, England
Panzer III MG Mount
- Has liked: 1024 times
- Been liked: 2093 times
Anthony
The AA mount on the Bovington Pz III is a simple piece of bent metal bolted to the drainage holes in the cupola ring. It was a local mod, particularly seen in North Africa. It was intended to mount either the MG 34 bipod or a simple mounting pintle.
In May 1943, a production standard mount, the Fliegerbeschussgeraet 42, was introduced on the production line although only the N model was in production that late.
Hope that helps.
Hope that helps.
Hi Stephen,
Fantastic, great photo's and diagrams. Thanks
On the bottom one wouldn't that configuration need a cupola ring
I particlularly like the one that uses the bipod as it gives quite a bit more elevation, I might go for that after I have drilled all the drainage hole.
Thanks for help,
Antony
Thanks for help,
Antony
