21st Panzer Division Pz.Kpfw III Ausf M Build
- Been liked: 177 times
Hi Antony
Your turret looks excellent! Especially with the primer on it. Great job on the light texturing. How about just a piece of "L" shaped brass for the rain guard?
Your build looks great! The PIII is really starting to grow on me.
- Location: Back to Wirral home of the brave or not so brave, England
Hi Tim,
Thanks alot .
I thought of the brass but the round cover on the top has a rain guard around it as well which needs to be round. Also the cover over the doors is sloped at the ends not straight. I'll go to B & Q tomorrow (DIY store) to see what I could use.
Thanks Antony
Thanks alot .
Thanks Antony
- Has liked: 8 times
- Been liked: 688 times
Antony
Your right . When i first saw your pictures i thought they looked wrong and had a quick look on Lee Sellers site were the door stops are on the other way round. I have now looked at some war time shots and you are quite correct in the positioning of the stops.
Lesson learned :-check the facts before making a statement.
See you soon
See you soon
Hi Steve,
No problem, if you hadn't mentioned the door stops I wouldn't have noticed I had the doors on the wrong way . I would always prefer someone to tell me my errors now rather than waiting until I'd finished. It makes it easier to fix them now rather than later .
Thanks Ant
Thanks Ant
- Has liked: 116 times
- Been liked: 1104 times
Hi Guys,
Reason for the door stops being that way is they are actually a sprung loaded ball that sits out the top of the cylinder. This allows the door to run over it and be held open. Without a good tug it won't swing back and crush your fingers!!!
Anthony if its not too much of a problem drop the commanders periscope guards out and turn them up the other way
Dave
Dave
www.armorpax.net
- Been liked: 54 times
Turret is looking good.
As Tim said you could use a piece of brass, just don't use a thick piece then you can make the slope on the ends.
Are you going top add the pistol port to the turret doors?
Here are 2 pictures showing the rain guard.
[/img]
For the signal port you may want to make it out of plastic, easier to work with.
[/img]
[/img]
[/img]
Hi Mike,
Great photo's, Thanks.
I spoke to Dave @ Armorpax and he said he maybe adding the pistol port to his parts to make but he was sure the later models didn't have this extra port. I must admit I have not seen a photo of one with it not installed so if he does make it I will certainly add them. I too thought it would be easier to work with plastic for the signal port. Thanks.
Thanks Antony
Thanks Antony
Hi Anthony,
The pistol ports were deleted on late version Panzer IV's such as the J (which these were originally made for) but I am not sure they were ever deleted on Panzer III's. Will try and get these done soon.
Dave
Dave
www.armorpax.net
Adding the rain guards over the turret doors and roof vent. Also turned the periscope guards round after Dave's advice. Thanks.
Decided in the end to use some aluminium conduit, cut and shaped to size.
Decided on 3 nuts as I've seen some photo's with 2, 3, 4 or even 5.
Roof vent rain guard made from lampshade rings. Perfect size too
Sloped the ends so the vent opens freely.
I'm pleased with the end result better than I thought they'd look
Next to start on the welds.
Thanks Antony
Thanks Antony
Cracking job Antony, I'd better get on with those door ports for you
Dave
Dave
www.armorpax.net
- Been liked: 10 times
- Has liked: 126 times
- Been liked: 755 times
